Petiterina
Well I can resist no longer!
So a Depron little Ballerina - "Petiterina"
3/4 the size giving 40" span.
The object is to use Depron as much as possible with the minimum of reinforcing and even then only balsa!
The wing plan modified to be built in 2 mm Depron with closer spaced ribs and a wide tapered spar that has balsa flanges just 0.8 mm thick. :ohmy:
I am still considering whether to use servos directly coupled to the ailerons as I used on the Endurance. Its a bit fiddly to set up but it does give a very 'clean' appearance with no external linkage.
At 3/4 the size it will only have just over half (9/16) the wing area so it will have to be less than half the weight to keep a reasonable flying speed.
The object is find out just how light it can go whilst still retaining a good performance (150W/lb?) along with a more than adequate strength.
And I haven't forgotten the Comet - I am waiting for the EDFs from China!
The rib template.
It is quite easy to accurately cut round this on 2 mm Depron - which is just as well as there are 26 to do.
The lower wing skin pieces.
When the 2 mm Depron is glued on top of the 0.8 mm balsa it does of course stand proud above te rest of the skin so it is notched with a suitable 2mm wide file.
This has the advantage as it provide a 'location' for each rib.
The ribs start to go in.
So far so good.
All 32 of them each individually fitted!
Then the front top skin and top spar flange.
In this state the wing is plaenty strong enough to be handled so a 6 mm Depron leading edge is added and carefully sanded to profile.
The RH wing in this state weighs 0.91 oz (25.8g)
I will make a start of the LH wing whilst I can still remember exactly how it is made! :woohoo:
Then the aileron is cut out and its servo glued in.
The original Ballerina had its undercarriage fixed into the wing using substantial hard wood mounts. I prefer a 'springy' undercarriage with significant vertical movement as this greatly reduces the shock loading on the mountings, an important consideration with a Depron 'moncoque' construction where the whole object to spread the loads as widely as possible.
Although the Petiterina will be quite a bit heavier I intend to mount the undercarriage as I did with the Depron Super Cub.
Strong acetate 'plates' glued to the side of the fuselage and carrying the relatively thin but braced undercarriage wires.
This restrains the wheel accurately but allows considerable vertical 'spring' movement.
The fuselage should look something like this.
I am not sure whether to add a steerable tail wheel. The Super Cub manages quite well with a fixed one simply relying on a burst of power to lift the tail and then steering with a boot full of rudder!
As this is a lightweight Depron build I have decided to use direct coupled ailerons servos and tiny ones at that.
The aileron is a bit shorter than the origianl but a bid wider to get the servo positioned within the skins.
With a 6 mm Depron leading edge and its top skin it can be sanded to the required nose shape. The servo horn is inset into the aileron.
So it mates up with the servo spline.
The aileron has a 'pin' hinge outboard.
With the wing top skin added the aileron can be tested.
The Tx has been programmed to give 50% differential movement.
The other wing half construction is catching up.
About time to start the fuselage.
I first used it on the Endurance's ailerons.
In that case simply to reduce the drag of the exposed horns.
There are 'hidden' systems but they tend to be mechanically inefficient and I needed to save the current.
The downside of direct acting is it tends to end up built in so any maintenance is a cu tout job.
The sides are the good Depron - its strong and flat - the formers are the softer and not flat 'aero' quality.
Built up in exactly the same way as with balsa.
In fact it will also be a 'thin' Ballerina as it has no doublers.
The underside is also 3 mm Depron but the rear decking uses 2 mm planks.
The question is how much has to be completed before I can determine where to put the battery? I don't do ballast.
The undercarriage wire formed along with the acetate side plates.
Actually push rod wire so it gives quite a 'soft' suspension.
The tail wheel uses similar but in a triangular arrangement.
Sitting on its wheels.
Tail feathers next.
The elevator has a glass fibre torque tube joiner that also acts as the 'pin' for the centre hinge.
The outer hinges are home made acetate pin hinges.
The fin is built the same way with two acetate pin hinges.
With the wing joined it can all be glued together. It begins to actually look like a Ballerina.
To save weight just the control surfaces are painted
Thanks,
Andy
Here you go.
I drill the holes with a sharp pointed needle file. The head end hinge flap is a close free fit. The other is a push interference fit.
Once assembled the excess pin length is cut off and the pin end secured with a dab glue. I use Gorilla glue.
One advantage is the acetate (or what ever the plastic sheet is!) can be cut a suitable shape/size to fit the wing/fuselage that it is being glued into. The one in picture was used on a sheet Depron fin/rudder.
The same principle can be used for much larger diameters. This is the acetate hinge flap on the 5 mm elevator torque tube used on the Petiterina.
Just 12.8 oz all up so with its 120W measured it has 150W/lb available.
The Petiterina maiden. Hand launch as the grass is quite long and rough but it actually ROGs nicely.
It has a Lemon 7ch gyro rx in it although the gyro was not used initially.
When I did switch it on it promptly tried to loop! Fortunately my finger was near the switch so the gyro was killed before things got out of hand.
Reason? The elevator gyro action was reversed! Oops! :woohoo:
My only defence is it is easy to miss exactly which way the gyro actually moves the surface.
Once corrected the gyro now makes it fly 'on rails' and dead straight too, so a suitable setting on the fail safe is important.
And yes at full chat it can go straight up!
Thanks also for the info on the hinges, that'll be very useful on my small scale models!
