Vought V173
- Flytilbroke
- Thank you received: 1987
But,, In France, and other eu countries with some variation. You are entitled to basic assistance including accommodation, food, legal, medical and psychosocial assistance (see topics below). You will have the right to work in France six months after submitting your application for international protection if the OFPRA has not yet taken a decision on your application.
A short video of it being run up on a 2s LiPo.
On a 2s it draws 6A giving 40W.
A bit heavier than I had hoped at 46g compared to 75g for the previous motor prop combination.
Now to see if I can actually make a V173,
The new slim nacelles on the plan.
Compared to the size of the "wing" there is an awful lot of prop!
My intention is to build the wing leading edge as a box spar to support the nacelles. Once complete the rest of the pancake will be a light weight foam/tissue build.
3 servos. One for each elevon and one linked to both rudders.
It just might end up not too far from 250g ready to go!
The "leading edge" of the V173 fuselage with the nacelles attached and one motor/prop in place.
It all fits together beautifully except it does not work.
These are 1300kV motors which is surprisingly low for their tiny (22.3mm) diameter. This of course means the windings are very fine to get the required turns in the available space which in turn means the motor lead outs have to be treated with extreme care to avoid breaking a wire where they are soldered on to the windings and we all know it is virtually impossible to repair without completely rewinding the motor.
Of course in my efforts to feed the motor wires down inside the nacelle I have indeed broken one of the motor wire connections and to make matters worth I have done the same to BOTH motors.
What a plonker! Really pissed off!
Two new motors ordered from Banggood via Canada! The 1300kV versions are not that easy to find. The new motors will be installed carefully just once and never touched again!
I suppose whilst I am waiting I can build up the rest of the V173 fuselage, its about all there is!
It will be tissue covered. After all the original was fabric covered.
Still quite a bit of design to do concerning the all moving elevons that have to be cantilevered out from a rather thin part of the rear wing wing.
The central rectangular opening is where I think the battery will need to go. The stab Rx will go in there too.
So far adding up all the motors, props, electrics and the airframe comes to 203g. Tissue, a springy undercarriage, elevons and servos mean it could end up not too far over 250g.
We shall see.
A LW-PLA structure with a 2mm carbon rod that will act as the pivot.
The carbon rod will go far enough into the thicker part of the structure so the servo will be completely buried.
I do wonder if the tail elevator should be included although all the aerial shots of the prototype flying show it at "neutral" suggesting it was only required for the landing flare.
- jon.in.swansea
- Thank you received: 1192
A close up of the printed servo connector.
What you can't see because its underneath is the servo arm so each servo can also drive the split rear elevator (not yet built) as "additional" elevons.
The chances of this actually flying must be pretty remote.
Each are LW-PLA "lofted" structures to create the complex 3 dimensional shape and are top tape hinged. The links rods to the servos should be entirely hidden within the airframe.
The tail elevons will only finally added once the airframe is electrically complete and tissue covered.
Next are the fins and rudders. Both rudders will hopefully be driven by a single central servo - somehow!
It is using a V tail mixer and a normal radio although the intended Lemon "stab" Rx has an "elevon" option built in.
https://<iframe width="560" height="315" src="" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" referrerpolicy="strict-origin-when-cross-origin" allowfullscreen>
Although it is a compact and light installation, everything ends up within the tissue covering, however in reality it only uses about 50% of the servo travel. At full servo travel the surfaces are at such an acute angle to the airflow they will simply be stalled.
I have a potential solution but it means adding further linkages, bearings and with the servos completely repositioned or in other words ripping it all out and starting again!
Still needs must.
