- Thank you received: 236
Fokker Eindecker E111
- old ugly
- Senior Member
- old ugly
- Senior Member
you think it would fly without? (assuming every thing else falls into place)
OU
The model might fly, but the slightest disturbance would cause it to fall into a spiral dive.
- old ugly
- Senior Member
so now i have to decide if I am going to fly it or hang it from the ceiling.
a major decision to make.
thanks guys
OU '
- old ugly
- Senior Member
It is amazing how small the scale tail plane is.
I also noticed in the model the main spar runs right through where the pilot sat but then realised that in full size there would be no spar across the fuselage as all the flying loads were carried by the rigging. In fact it had to be as the rigging could be altered by stick movement to create the wing warping for roll control.
If you think about it wing warping creates "wash in" rather than "wash out" so promoting wing stalls starting from the tip (bad!) and coupled with zero dihedral it is not surprising that rapid maneuvering of the Eindecker was considered dangerous.
Quote from wiki -
All the E.I to E.IV Eindeckers used a gravity fuel tank which had to be constantly filled by hand-pumping from the main fuel tank, which, starting with the Fokker E.II , was mounted behind the pilot; this had to be done up to eight times an hour. Both the rudder and elevator were aerodynamically balanced; there were no fixed tail surfaces. This combination rendered the Eindecker very responsive to pitch and yaw . For an inexperienced pilot, the extreme sensitivity of the elevators made level flight difficult; German ace Leutnant Kurt Wintgens , who along with Leutnant Parschau was the primary Fliegertruppe pilot responsible for bringing the first armed Fokker monoplanes into active service during the spring and summer of 1915, once stated "lightning is a straight line compared with the barogram of the first solo". However roll response was poor.
- old ugly
- Senior Member
- old ugly
- Senior Member
- old ugly
- Senior Member
he is a big guy for that plane.
