2500MM ASW17
17 Feb 2022 03:14 - 17 Feb 2022 03:15 #1 by molan
2500MM ASW17 was created by molan
Wingspan: 2500mm /98.4 in
Overall Length: 1390mm /54.7 in
Flying Weight: Around 3500g
Motor Size: 3541 KV750
Esc With Brake: 40A
Servo: 17gX4pcs
Servo: 9gX2pcs
Radio: 6CH Channel
FMS is proud to announce the brand-new 2500MM ASW17 2500mm ASW-17 !
True to the FMS spirit, no detail was overlooked in the design of the ASW-17. The FMS engineers made 4 expensive tooling adjustments just to micro-adjust the airfoil for perfect efficiency.
The wing, vertical and horizontal stabilizers are designed with a snap-together structure. With a simple snap, the surfaces attach to the fuselage with pinpoint precision- no screws or glue necessary! Build the aircraft in as little as 3 minutes!
Like the 3000mm Fox, the ASW-17 has a pre-installed carbon fiber spar that ensures wing rigidity in high-G maneuvers.
To achieve the same dihedral as the real aircraft, the ASW-17 was designed with a specialized CNC aluminum spar joiner- allowing the aircraft to maintain its wing geometry during demanding flight routines.
Performance-wise, a high-quality Hobbywing 40A ESC paired with a Predator 3541-750KV motor provides ample power with a 4S pack to perform most aerobatic maneuvers.
If efficiency, stability and aerobatic capabilities are what you seek in a glider, look no further than the FMS 2500mm ASW-17!
Last edit: 17 Feb 2022 03:15 by molan.
17 Feb 2022 08:35 #2 by Eric
Replied by Eric on topic 2500MM ASW17
From where, and how much?
  • Away
17 Feb 2022 10:12 #3 by Flytilbroke
Replied by Flytilbroke on topic 2500MM ASW17
Wheelspin Models £242:19, says Google search. Other UK model shops advertise it too.
Time to create page: 0.416 seconds
