TOPIC: Basic model
Basic model 17 Feb 2016 15:19 #16
  • Online
  • More Details
    • Thank you received:847
Looks good Tony
Anything will fly give n enough power
Basic model 17 Feb 2016 15:41 #17
  • Tony B
  • Tony B's Avatar
  • More Details
    • Thank you received:11983
i think the arse end is too fat, needs thinning down a touch me thinks.
but that would mean building a new fuselage and i am almost out of material. :(
as René Descartes said. " i build therefor i am "
Basic model 17 Feb 2016 16:24 #18
  • Online
  • More Details
could you you not take a wedge out and glue it back down Or lift the top and slice some off then replace the top .Or bottom It's only Depron isn't it .
Basic model 17 Feb 2016 22:29 #19
  • Online
  • More Details
lovely . Have you finalised the wings planform now ?
Basic model 18 Feb 2016 04:07 #20
  • Doug
  • Doug's Avatar
  • More Details
    • Thank you received:56
I think the tailplane/fin are too small which gives the illusion of the large rear end. May look better with the elevator fitted but the fin definitely needs enlarging.
Doug
The following user(s) said Thank You: Tony B
Basic model 18 Feb 2016 07:23 #21
  • Andy Sephton
  • Andy Sephton's Avatar
  • More Details
    • Thank you received:6186
I must admit that I agree with Doug, Tony. I reckon it'd benefit from a larger span tailplane and a taller fin. You don't need to make either of them fatter.
Given that the model is made of Depron, it's a trainer and it's going to take some punishment, so the back end being a little deeper than it should be is a good thing. The larger empennage will also add stability, which is also a good thing for a trainer.
Too much thrust is never enough!
Basic model 18 Feb 2016 16:54 #22
  • Tony B
  • Tony B's Avatar
  • More Details
designed and made a bigger fin and tailplane today. :P
plan has been altered to match now. back to revisions tonight. ;)
The following user(s) said Thank You: Klipkopwildlife, Quorneng, Andy Sephton
Basic model 20 Feb 2016 06:18 #23
  • Andy Sephton
  • More Details
That fin looks a lot better, Tony, and the rear fuselage depth now looks in proportion with the rest of the model.
Well done mate! :) :)
Basic model 21 Feb 2016 16:54 #24
  • Tony B
  • Tony B's Avatar
  • More Details
Took some time off from the camper to do a little bit of painting.
The following user(s) said Thank You: Klipkopwildlife, Andy Sephton
Basic model 22 Feb 2016 18:09 #25
  • Tony B
  • Tony B's Avatar
  • More Details
Finished painting the fin and tailplane today.
fitted the rudder and elevator snakes as well.
so if i get time tomorrow i will finish sheeting the top of the fuselage.
need some wire for the u/c and a battery box next.
Basic model 23 Feb 2016 12:47 #26
  • Tony B
  • Tony B's Avatar
  • More Details
finished sheeting the top of the fuselage now.
will leave the front open until after i have fitted the esc and u/c.
so i need to sand the edges round and i can cover the fuselage and make it ready for paint.
Basic model 24 Feb 2016 17:56 #27
  • Tony B
  • Tony B's Avatar
  • More Details
Covered the fuselage today and started adding some paint.
Basic model 25 Feb 2016 17:50 #28
  • Tony B
  • Tony B's Avatar
  • More Details
fuselage painted.
wings next
The following user(s) said Thank You: Klipkopwildlife, blue123, Andy Sephton
Basic model 26 Feb 2016 00:20 #29
  • Online
  • More Details
Lovely job sir .BTW what did you cover with Tissue or something else
Basic model 28 Feb 2016 18:47 #30
  • Tony B
  • Tony B's Avatar
  • More Details
well today i bent up and glued home the elevator joiner, then fitted the elevators.
fitted the rudder and then glued the tailplane/ fin ensemble to the fuselage.
i also fitted the wing dowels.
need some wire for the u/c now and we can finish the fuselage off.
i have more depron coming on Tuesday ( i hope) so i should be able to construct the wing next week.
soon be finished and i can then start the next daft idea. :P :P
Time to create page: 0.272 seconds
Amount:
 GBP
