TOPIC: Basic model
Basic model 29 Feb 2016 18:11 #31
  • Tony B
  • Tony B's Avatar
  • More Details
    • Thank you received:12340
Ribs
Ribs
Ribs
Ribs
and
yup Ribs
enough ribs for five wings now.
Duster, diamond, double diamond and the dagger.
as René Descartes said. " i build therefor i am "
Last Edit: 29 Feb 2016 18:17 by Tony B.
The following user(s) said Thank You: Klipkopwildlife, Quorneng, Andy Sephton
Basic model 29 Feb 2016 23:36 #32
  • Quorneng's Avatar
  • More Details
    • Thank you received:8502
Could be a bit of a sod if you find you need to change anything when you build the first wing! ;)
Basic model 02 Mar 2016 17:32 #33
  • Tony B
  • Tony B's Avatar
  • More Details
Well i have started the wing today.
so far all the ribs i pre-cut have fitted perfectly :P
i had to roll the leading edge slightly so it would match the curve of the ribs for gluing.
when my lite ply turns up i can make thee dihedral braces and run the servo wires ready for the top sheeting to go on.
The following user(s) said Thank You: Klipkopwildlife, Quorneng, Andy Sephton, one tenor
Basic model 03 Mar 2016 17:29 #34
  • Tony B
  • Tony B's Avatar
  • More Details
well today i made the dihedral braces and glued the two wing halves together.
then i sheeted the top of the wing with some 3mm Depron.
need to do the tips and ailerons next and then it can be covered and painted.
that just leaves battery box, u/c, final fuselage sheeting and the motor/esc.
nearly done ready for crashing.
:P
The following user(s) said Thank You: Klipkopwildlife, The Beard, Quorneng, Andy Sephton
Basic model 04 Mar 2016 18:22 #35
  • Tony B
  • Tony B's Avatar
  • More Details
Wing tips designed and built.
need sanding next.
cant do the ailerons until i get some control horns, need more tissue and polyc as well, my daughter used the last of mine up. :angry:
The following user(s) said Thank You: Klipkopwildlife, Quorneng, blue123, Andy Sephton
Basic model 05 Mar 2016 18:25 #36
  • Tony B
  • Tony B's Avatar
  • More Details
well not much to report today been rebuilding bedroom walls instead.
still we can have a pose picture of the two models together. :P :P
The following user(s) said Thank You: Klipkopwildlife, Andy Sephton
Basic model 18 Mar 2016 19:11 #37
  • Tony B
  • Tony B's Avatar
  • More Details
covered the wing yesterday and decided that i would slop a bit of paint about this afternoon.
Basic model 20 Mar 2016 16:24 #38
  • Tony B
  • Tony B's Avatar
  • More Details
Painted the underside of the wing today and added the name.
Basic model 20 Mar 2016 16:35 #39
  • Online
  • More Details
    • Thank you received:990
Not just Dad's taxi then but Dad's modeling supplies as well eh! Is she building planes as well then ?
Anything will fly give n enough power
Last Edit: 20 Mar 2016 19:30 by Garry Pollard.
Basic model 14 Apr 2016 20:34 #40
  • Tony B
  • Tony B's Avatar
  • More Details
battery box is sorted
ailerons made and fitted, just need painting
got the u/c to make and the motor/esc to buy and fit.
will be finished this month,
Basic model 15 Apr 2016 00:10 #41
  • Online
  • More Details
Very nice Tony. How are the DD and the high wing job coming along ? BTW Tony did you get a big cardboard box yet? It can make a spray booth. If it is big/deep enough it will contain 99% Of the spray
Last Edit: 15 Apr 2016 00:33 by one tenor.
Basic model 17 Apr 2016 11:17 #42
  • Tony B
  • Tony B's Avatar
  • More Details
Finished of the last few bits to this this morning.
ok i need a motor/esc and servos now and i can put this one to bed.
The following user(s) said Thank You: Klipkopwildlife, Quorneng, blue123, Andy Sephton, boz
Basic model 17 Apr 2016 18:15 #43
  • Quorneng's Avatar
  • More Details
I was actually rather hoping you might fly it. :P :P
The following user(s) said Thank You: Klipkopwildlife, Tony B
Basic model 19 May 2016 18:50 #44
  • Tony B
  • Tony B's Avatar
  • More Details
I finally had enough money to order the motor, esc and servos for the duster.
they turned up this morning and i have managed to fit the motor and servos.
need some 3.5mm bullets so i can wire up the esc.
so this one is nearly finished at last. yaaaaaaaaaaaaaaaaaaay.
The following user(s) said Thank You: Klipkopwildlife, Quorneng, Andy Sephton, boz
Basic model 28 May 2016 12:59 #45
  • Tony B
  • Tony B's Avatar
  • More Details
another on done, just about. :P
The following user(s) said Thank You: Quorneng, blue123, Old Fart, Andy Sephton, boz
Time to create page: 3.151 seconds
Amount:
 GBP
