- Thank you received: 8
ppm?
- don49
- New Member
25 Mar 2021 18:12 #1
by don49
ppm? was created by don49
hi all how to ppm with a reciever board that only has a wifi socket free..?.. will a 'y lead' into a servo socket and sharing it with the servo work ..??..
I have a120 fp heli and want to use my big tx for all the models, but this one is.the wrong language rx.
also would separates be available .. micro esc and hh gyro... to do away with the board even and setup as a bigger heli is... don't like all the 6 point gyro stabilisation..
don
don
25 Mar 2021 18:37 #2
Replied by Eric on topic ppm?
What receiver are you talking about - I've never heard of one with wifi!
What transmitter are you using?
the abbreviation ppm usually means parts per million. (or it could be pulse proportional modulation)
- don49
- New Member
25 Mar 2021 23:18 - 25 Mar 2021 23:21 #3
by don49
Replied by don49 on topic ppm?
the reciever is a control board on the firefox from banggood .a fp heli with full stablisation
ppm pulse proportional modulation, 1 servo wire connection between recievers allows full control of model ... an older rc term..
I assume the wifi connection is there for camera or perhaps control through an app on smart phone ..
but board is not setup for ppm etc as most recievers are ..
Last edit: 25 Mar 2021 23:21 by don49.
26 Mar 2021 08:36 - 26 Mar 2021 08:46 #4
I've had a good look on Banggood, and cannot find any heli called Firefox. So that was a blind alley. Is it a model of the TV Firefox, or just called Firefox?
PPM - All r/c radio sets are pulse proportional, so that tells me nothing, either! It just means that the servo moves to follow the stick movement.
So - I ask again - what brand and model number of transmitter are you using?
What brand and model number of reciever are you using?
What are you tryng to get them to do?
You have to bear in mind that a lot of radio-control manufacturers have their own particular 'code' that the transmitter sends to the receiver, so it's a bit like a cross language discussion between a French man and a Russian man, neither of them speaks the other's language, so they don't get very far!
For example, Futaba uses FASST, Spektrum uses DSMX, and Taranis uses ACCST, and none of them will 'talk' to each other. Then there are all the different 'dialects' within the same manufacturer's range - ie a Brummie and a Geordie trying to chat to each other! Up to a point, they use the same words, but they mean different things, and sound different!
Last edit: 26 Mar 2021 08:46 by Eric. Reason: added a comment
26 Mar 2021 17:04 #5
Replied by Klipkopwildlife on topic ppm?
Not exactly correct Eric, many TXs can be set to PPM or PCM. You do have to be very careful buying from Banggood. The information is there most of the time but you can end up being disappointed, I have some 1.7gm servos that I can't use because they have 1.25mm JST plugs, not the 1.0mm JST sockets that the micro RX is fitted with.
26 Mar 2021 17:05 #6
Don, some pictures of what you have would be nice. Eric and I have a lot of experience between us I'm sure we can help.
- Rich griff
- Thank you received: 344
26 Mar 2021 21:18 #7
by Rich griff
Replied by Rich griff on topic ppm?
Is ppm pulse position modulation, and pcm pulse code modulation ?
I am 22 years out of date and things change rapidly especially these days..
26 Mar 2021 23:36 #8
Klippy put - many TXs can be set to PPM or PCM.
Yes, I know, I was tryng to avoid over-complicating matters with even more code letters!
Rich - PPM can be either, depends on the manufacturer and the translater!
- Rich griff
27 Mar 2021 07:38 #9
by Rich griff
Thanks Eric, you live and learn...
Time to create page: 0.688 seconds
