Futaba T8FG
- crash happy
- Thank you received: 1203
Klipkopwildlife wrote: Hmmm, I don't like unresolved issues! They usually come back to bite you, when you least expect it!
I have suffered from that very problem over the years, normally with ex wives ! :pinch: :whistle:
- crash happy
Been there, that was a lesson I learned very quickly. Sometimes you can't see the wood for the trees ! I now have a bag full of servo reverser's for when I still get it wrong !:whistle:The Beard wrote: ive spent 2 days mulling over setting up the throttle just wasnt happening the answer turn the servo round duh
Won't work, the output arm/disc still rotates the same way, unless it has been mounted on it's side.
Now, if you turn the servo over, top for bottom, THEN you get a 'reverse' rotation.
Bring back the old servos, where you could get inside, and change two wires on the feedback pot, and the two wires on the motor, to make it go the other way!
Or - use your fancy computer radio, go into programming, and select servo reverse on the required channel!
In which case, why bother turning the servo round, because then you have to alter the length of the pushrod as well! [badass]
