- Thank you received: 1420
Battery fix
- boz
24 Jan 2018 06:49 #16
by boz
Replied by boz on topic Battery fix
when charging battery's in the house would it be safer to use a dedicated fire safe bag? I have seen them on ebay in different sizes. It would be safer and less of a worry, containing any explosion but more importantly no risk of a fire, they are fairly cheap and would give you piece of mind especially if you charge during the night.
24 Jan 2018 08:49 #17
Replied by Klipkopwildlife on topic Battery fix
Good advice there Boz. Where Lipos are concerned, since the maximum charge time is 1 hour at a standard charge, is it really much of a hardship to stick around until the charge is complete?
Nicads are now a thing of the past, or should be, any packs still around must be well past their use by date! With Nimh cells I would recommend paying a little extra and buying Enelope (Sanyo) They are a pleasure to use and never seem to give problems.
24 Jan 2018 09:22 #18
Replied by Eric on topic Battery fix
Agreed, Boz, but those bags hadn't been invented back then! They are really intended for lipo's, which can burn like a magnesium flare, IF they decided to 'let go'. (Touch wood, none of mine has, yet, although a few have puffed up, and been caught and removed to a safer place while they think about it).
It is less fiddly to charge them on a concrete floor, away from anything that can combust, especially, as I do, you charge several packs at once.
If you use those fire-bags, you have to have a separate one for each pack that is on charge - just in case - as if you have them all in one pack, and a cell decides to conflagrate, you have lost ALL those packs - and that gets expensive!
24 Jan 2018 11:00 #19
A caveat if I may, batteries have a finite life, it's well worth keeping a record of when they were charged. Once you start getting close to 1000 it's time to say goodbye. I consider any attempt to revitalise a battery that is going to fly in a model to be foolhardy and dangerous, unless like I do you live 3.5kms from your nearest neighbour! And I still wouldn't do it, models are just too valuable.
Time to create page: 0.834 seconds
