Digital multi meter
08 Mar 2018 13:24 - 08 Mar 2018 16:21 #16 by Klipkopwildlife
Replied by Klipkopwildlife on topic Digital multi meter
Non intrusive current measurement is now very affordable, check this out. This meter will even allow you to see current drain from the Lipo while you're running the motor!
Last edit: 08 Mar 2018 16:21 by Klipkopwildlife.
08 Mar 2018 15:37 #17 by one tenor
Replied by one tenor on topic Digital multi meter
Link not working Klip
08 Mar 2018 19:57 #18 by THE BLACKBIRD
Replied by THE BLACKBIRD on topic Digital multi meter
I have these meters, had them years, from giant cod, thing is i bought one of the blue ones did not use it for a while and when i did, nothing it did not work :unsure: so i bought another it worked for a short time then packed up, plug the battery in and the screen tells you it is not connected to the battery ??????
The black one i bought around the same time but it just tell the power your drawing, so not much use
I dont seem to have much luck with electrical stuff
08 Mar 2018 20:01 #19 by one tenor
I'd open them up and go over all soldered joints with a good hot iron and fresh solder . Nowt to lose
08 Mar 2018 20:38 #20 by Eric
Replied by Eric on topic Digital multi meter
Klippy's link works ok for me - Bang-good clamp-meter.
08 Mar 2018 22:33 #21 by Quorneng
Replied by Quorneng on topic Digital multi meter
To be fair to OT it did not work when it was first posted but presumably as a mod he could secretly fix it. :P
09 Mar 2018 02:23 - 09 Mar 2018 02:25 #22 by one tenor
Quorneng wrote: To be fair to OT it did not work when it was first posted but presumably as a mod he could secretly fix it. :P
Yep it's working for me now. Looks good Good old Bang Good He He
Last edit: 09 Mar 2018 02:25 by one tenor. Reason: correction
09 Mar 2018 07:37 #23 by Klipkopwildlife
Busted! B)
09 Mar 2018 07:39 #24 by Klipkopwildlife
Let's put the black one to one side and concentrate on the blue ones. Take a Lipo that you know has voltage and plug it in, first one, then the other. What do you get?
09 Mar 2018 12:00 #25 by boz
Replied by boz on topic Digital multi meter
Ya plug the blue one in, the black one out, in, out, shake them all about, oh, oh, the lipo cokie. :woohoo:
09 Mar 2018 16:47 #26 by one tenor
Klipkopwildlife wrote: Let's put the black one to one side and concentrate on the blue ones. Take a Lipo that you know has voltage and plug it in, first one, then the other. What do you get?
In line with this convo see this
hobbyking.com/en_us/hobbykingtm-lipo-vol...=cpc&utm_campaign=eu Very handy
09 Mar 2018 20:16 - 09 Mar 2018 20:20 #27 by THE BLACKBIRD
Bugger all on the first one :( Then on the second one i plugged a 4s lipo in, i know its ok because i use it on my kerosene pump, i get this
i press enter, i get this
Press again
And again
These were new and have never done anything
And just to top things off the Power Box sensor switch in the Revolver packed up today :( :angry: :S :evil: :sick: [badass]
Last edit: 09 Mar 2018 20:20 by THE BLACKBIRD.
Thanks: Klipkopwildlife, boz
09 Mar 2018 21:06 #28 by Eric
The Wattmeter I have is rather different to BB's - but as he has no load on the output, if I do that with MY meter, it shows 0.00 per cell. That's not VOLTS, it is AMPS, and as none are being drawn, 0.00 is correct. :P
Now - if BB plugs in a speed controller to the LOAD side, and a prop-less motor ( for safety), and a servo tester or receiver to drive the speedo, he'll see a difference!
A propless motor won't draw very much anyway, but the numbers will rise from zero.
09 Mar 2018 21:18 #29 by THE BLACKBIRD
I see it will not measure the lipo, only works if the is a flow through it, i will have to buy another lipo tester
Thank you
09 Mar 2018 22:57 - 09 Mar 2018 22:59 #30 by Quorneng
BB
It seems you have the wrong style of watt meter.
When I couple a lipo (a 2s in this case) up to mine just by itself it does indeed act as a volt meter.
It also shows the current it draws doing it (0.01 A). Left running it even records the power consumption, 0.009 Watt hours after 5 minutes!
Last edit: 09 Mar 2018 22:59 by Quorneng.
Time to create page: 1.529 seconds
