- Thank you received: 3
Setting FailSafe with Futaba receiver and RadioMaster TX16S
- Nigel Ellis-Gray
- New Member
06 Mar 2022 12:19 #1
by Nigel Ellis-Gray
Setting FailSafe with Futaba receiver and RadioMaster TX16S was created by Nigel Ellis-Gray
On the recommendation of a friend I bought a Futaba receiver for use with my TX16S. I was able to bind this successfully but not to set up FailSafe. Under model setup on the TX16S the Internal RF mode is: MULTI Futaba SFHSS.
I followed the Futaba instructions but that didn’t work. Perhaps they only apply if using a Futaba transmitter?
Is there a solution to this difficulty.
06 Mar 2022 12:47 #2
Replied by Klipkopwildlife on topic Setting FailSafe with Futaba receiver and RadioMaster TX16S
Exactly what RX is it Nigel?
- Nigel Ellis-Gray
- New Member
06 Mar 2022 13:58 #3
by Nigel Ellis-Gray
Replied by Nigel Ellis-Gray on topic Setting FailSafe with Futaba receiver and RadioMaster TX16S
It is a R2006GS. sorry forgot to mention that. A senior moment I suspect!
06 Mar 2022 16:45 #4
We all have them so welcome to the club. Investigation in progress.
- Nigel Ellis-Gray
- New Member
06 Mar 2022 17:19 #5
by Nigel Ellis-Gray
Thank you. Look forward to hearing from you hopefully.
11 Mar 2022 12:57 - 11 Mar 2022 12:58 #6
Well I've looked into this, and the first thing is, only the throttle, Ch 3, can be set to Fail safe. If TX power is lost or the battery is low the RX holds the last throttle position for 1 second, then uses the throttle position that was set during the Bind procedure. The F/S can be reset by setting the throttle to the desired position and pressing the range button (not the Easy link button) for more than 2 seconds. This is of course with everything switched on and linked.
Last edit: 11 Mar 2022 12:58 by Klipkopwildlife.
Thanks: Eric, Quorneng
- Nigel Ellis-Gray
- New Member
13 Mar 2022 14:19 #7
by Nigel Ellis-Gray
Thank you for the information.
Time to create page: 0.665 seconds
