Futaba 14SG spares?
26 May 2023 17:30 #1 by Klipkopwildlife
Futaba 14SG spares? was created by Klipkopwildlife
As commented on 'Been Flying' the Rudder trim on my 14SG isn't working, while flying a few days ago I noticed that left aileron trim was erratic, not good so I decided to attempt a repair. These are the buttons, 6.15mm in diameter, standing just over 4mm off the board, does anyone know where I can find these?
They only have 2 legs, the ones that are fitted to most appliances have 4
It must be a function of our heat and low humidity, I've had to fit new push buttons of the 4 leg variety to a number of our appliances.
  • Dragonfly
26 May 2023 17:49 #2 by Dragonfly
Replied by Dragonfly on topic Futaba 14SG spares?
These do you Klippy www.aliexpress.com/item/1005001949025888.html
there from ali express
26 May 2023 18:39 #3 by Eric
Replied by Eric on topic Futaba 14SG spares?
Or these from RS - 9p each. - packs of 10 - uk.rs-online.com/web/p/tactile-switches/0102399
27 May 2023 08:27 #4 by Klipkopwildlife
Replied by Klipkopwildlife on topic Futaba 14SG spares?
Thanks Bill, sadly these will be way too tall.
Thanks Eric, these are surface mount, they would probably do the job if I could find a way to solder them down.
27 May 2023 08:56 #5 by Klipkopwildlife
Thanks guys, knowing what the correct terminology is does help, I found exactly the right ones on Aliexpress, 10 for a pound, a fiver for postage but now the order won't go through!
27 May 2023 09:30 - 27 May 2023 09:36 #6 by Eric
I've had the same trouble with Ali. I found that if I kept logging in with a different passwords until I found one it liked, I could place an order, but had to revert to my original password to see updates for delivery, etc!
It's a weird system! I prefer bang-good, but that seems to have gone downhill recently, a bit like Hobbyking!
The main bugbear of any of them is the anything up to 28 day delivery times.
Last edit: 27 May 2023 09:36 by Eric.
Time to create page: 0.969 seconds
