Capillary tubing
05 Nov 2017 04:53 #1 by one tenor
Capillary tubing was created by one tenor
Anyone know where I can get capillary tubing from ?
05 Nov 2017 08:01 #2 by Eric
Replied by Eric on topic Capillary tubing
Best I can suggest is a laboratory supplies place.
What's it for?
05 Nov 2017 08:16 #3 by Mike Rolls
Replied by Mike Rolls on topic Capillary tubing
John
If you just Goggle capillary tubing there are a lot of hits - various materials, various sizes, etc.
06 Nov 2017 00:20 #4 by one tenor
Replied by one tenor on topic Capillary tubing
Thanks Mike
06 Nov 2017 05:14 #5 by Mike Rolls
You're welcome - hope you find what you want
08 Nov 2017 02:16 - 08 Nov 2017 02:18 #6 by one tenor
Yep ta Ordered a length of 1.8 mm and asked about 1 mm availability. It's to try repairing an old CO2 motor I have Thanks again John
Last edit: 08 Nov 2017 02:18 by one tenor.
17 Nov 2017 00:29 #7 by Nigel
Replied by Nigel on topic Capillary tubing
OD or ID OT (I did a funny :P )
Copper or stainless ?
17 Nov 2017 02:55 #8 by one tenor
OK I got it
20 Nov 2017 23:12 #9 by Nigel
Hmmm, actually interested in the answer too, and supplier if possible please?
20 Nov 2017 23:40 #10 by one tenor
Sorry Nigel 1.5 mm copper. From a site on E Bay Can't tell you more except it arrived German postmarked
23 Nov 2017 00:17 - 23 Nov 2017 00:19 #11 by Nigel
Thanks. It might actually be improved using the larger pipe. I was reading the back of the box for a Telco Turbotank the other day. It claimed the turbotank version was considerably more powerful than the standard, for two reasons. One was (probably) twaddle (I need to verify somehow, maybe sawing up an old worn tanker), the other reason was stated simply because the length of pipe between tank and head was minimised.
My guess is they are implying the pressure drop in the pipe is therefore minimised. Makes sense, there's pressure drop when any fluid (gas and liquid) moves along a pipe, around bends, etc, worsened by smaller diameter pipes. Ask a plummer or gas fitter. Notwithstanding wall thickness of copper cf stainless, the bore of your new pipe may provide higher pressure gas at the engine, thus increasing power (or duration at the same power). It needs some scientific testing...
N
Last edit: 23 Nov 2017 00:19 by Nigel.
23 Nov 2017 01:19 #12 by one tenor
What a bigger bore pipe does is increase the volume of flow and reduce the pressure Nigel .
23 Nov 2017 07:26 #13 by Squirrelnet
Replied by Squirrelnet on topic Capillary tubing
Sounds very logical John but I think the opposite is true, the larger the pipe the higher the pressure.....something to do with Newton's 2nd law which is a bit beyond me :whistle:
23 Nov 2017 21:49 #14 by Nigel
one tenor wrote: What a bigger bore pipe does is increase the volume of flow and reduce the pressure Nigel .
er, no, sorry John that's not correct in this context; bigger bore reduces the pressure drop so the delivered pressure will be higher at the outlet, assuming a given starting pressure like the CO2 tank. happy to discuss other situations or agree to differ.
Anyway, for reference, I measured a few CO2 motor pipe diameters last night. Only a dial calliper so half a thou accuracy at max. Conversion to metric to suit yourself but they look like imperial sizes to me. The G-69 is a metricised version of the G-63 with plastic crankcase made for Aerographics.
For reference:
G-24 .0225" stainless, glued
G-28 .023" same
G-63 .03125"
G-69 .032"
G-120 .0325"
G-300 .0475"
Modela 0,27 .0765" soldered (tinned copper?)
KK 100 (?) .0635" soldered (tinned copper?)
Thanks: boz, Squirrelnet
24 Nov 2017 12:48 #15 by one tenor
Of course it's gases isn't it
Time to create page: 1.301 seconds
