Cassna Bits
So called because it is made up of bits (wings) from the now defunct Cessna Skymaster.
Fully complete with 35 meg Rx but testing showed a rather questionable LH aileron servo. This was probably why it was in the loft.
Anyway 2 days back it was calm in the evening so I chose to fly it anyway. It always did fly very well and it still does except as I was coming in to land the LH aileron decided to stick almost full up. No chance to correct the roll so it went in nose first.
Did the usual Depron trick of crushing the nose almost back to the wing leading edge but no other damage.
A nose rebuild.
The motor mount, the nose former and spinner are printed components for which I still have the stl files.
You would be hard put to even notice the new LH aileron servo.
Nice simple Depron building. Makes a change from the tricky EDF stuff.
One part that worked really well if fact better than the original version is the printed 2 part spinner.
The spinner back plate is just 0,2mm clear of the nose former and it runs true too.
Actually flew it both am and pm 5 minutes each time. I was going to video it but my video cam battery has given up the ghost.
Courtesy of a generous 9x6 prop and its light weight of 370g (13 oz) with a 1500mAh 3s on board it has both true vertical and a very low power cruise. Based on the consumption of todays flights it should be able to manage close to 30 minutes.
About my only grumble is the significant trim effects when applying power. Its current 35Meg radio has no mixes but if I change to 2.4 both proportional elevator and aileron trims could be added to substantially compensate for throttle position.
The replacement nose is making progress.
The damage was rather more than just replacing the nose skin as the battery is now further forward requiring some modification to the fuselage internal structure.
The crash broke the 9x6 prop. These used to be "two a penny" on Ebay but are now scarce and expensive as it is not a popular size for quads. 2 pairs (CW & CCW) of 9x5s for not much more than for a single 9x6!
It does show where the demand is and its not for RC plane spares
- jon.in.swansea
- Thank you received: 1192
Tony mentioned he was using a particularly high strength PLA for bits of the
Big Bobber. Any one tried that kind of filament on a prop - it might stand up to higher revs?
I have not yet made a prop from a downloadable stl file for a filament printer that produces a prop matching the "thinness" of a commercial e-prop and certainly not the surface finish without considerable hand finishing that rather defeats the object of doing it in the first place.
I still wait to be amazed!
- jon.in.swansea
step up size from what I remember with the Fun Cub ( I could be wrong about that)? What
sort of shaft diameter and hub thickness would you be looking to accommodate?
Cautious me would prefer testing the idea out on a 9 or 10" prop first. There are going
to be some serious stresses near the hub if RPM shifts quickly. I will have a think about this....
I remember an experiment I did with surface finishing and balancing was to brush
on a thin coating of clear resin rather than endlessly try to sand down the surface.
A comparison between a printed 9x6 stl file downloaded from Thingyverse compared to a 9x6 "slow fly" prop.
Apart from the work required to give the printed prop blades a smooth finish whilst they very strong & stiff have a much thicker section, actually16% t/c at 1/4 span. The slow fly is just 8% t/c at the same point.
I would suggest that although the printed prop was marked as an electric prop its form is much closer to an IC type.
Just out of interest I used the CURA "scale" facility to create a 10x6 and 7x6 as well.as the original 9x6.
The Cessna Bits rebuild is nearly complete.
I'd have to set up a test rig, testing in a plane would rip the motor out if a blade became detached.
6mm shaft
- jon.in.swansea
And to correct it's balance rather than 'subtractive' sanding. I would do
20-30 seconds of sanding only and then put it on the balance stand.
I brushed a thin coating of clear two part resin on the 'lighter' blade.
Take if off the balance so it could start curing in a horizontal position, wait
5 minutes to stiffen and re-check the balance and if needed brush
a bit more on. Once balanced transfer to a curing rod and mount the next prop for testing.
Then let the lot finish curing overnight.
It takes awhile for the resin to cure but saved lots of time and arm pain in the sanding. I didn't
spend much, if any, time to make the resin a beauty coat. I certainly sorts
layer lines and minor blemishes.
