A new operating system
10 Apr 2026 18:25 #1 by Klipkopwildlife
A new operating system was created by Klipkopwildlife
With many Governments and Companies dropping Windows in any form I thought I'd find out why, and what can be done about it.
It turns out that Microsoft has been using Windows to gather information about the users, the worst culprit is Windows 11.
Although I don't use Windows 11, the installation of Windows on my new computer attempted to install it for me, necessitating a complete re-format of my hard drive. I was not a happy chappy.
A friend of mine recommended Linux (beware, the way they pronounce it it should be spelled Linnux!)
Having used Linux many years ago I was a bit wary since my brain isn't what it once was.
I looked around and found Linux Mint Cinnamon and thought I'd give it a go.
Thanks: Flytilbroke, Quorneng
11 Apr 2026 05:40 - 11 Apr 2026 06:00 #2 by Magpie
Replied by Magpie on topic A new operating system
I've got a touch of Blackbird's trouble. I woke up at 2.00am for a comfort break & couldn't get back to sleep because my brain wouldn't switch off (or go to sleep anyway) so I got up at 4.30 & here I am.
I've been thinking about installing Linux for a while because Windows continually gets up my nose. This new computer is Windows 11 & I set it up to my satisfaction but not to Microsoft's apparently so it regularly tells me to finish the installation by joining the cloud & sharing everything amongst all my devices of which I only have one - this one!
It obviously wants to know what I'm doing.
When I got this one I decided to clean up my old Windows 7 machine which still works as well as it ever did & reinstall Windows 7. A couple of years after I got it, it picked up a virus or something which no anti-virus software could clear so I bought an installation disk & reformatted the hard drive & reinstalled windows. So I reformatted it again & reinstalled Windows 7 from this disc. Everything went OK until I tried to register it with the code that came with it. But now of course Microsoft have dropped Windows 7 so it keeps telling me the code is invalid & the phone service has been dropped.
Now it keeps telling me I may have pirated software & am at risk! Of course everything works but I keep getting a warning message. I looked on the internet & found a command to disable it but that command cannot be found on my computer.
So I intend to install Linux on it when I have established that LaserGRBl will work on it as I now only use it to run my laser cutter. My son uses Linux at work so I'll have him for help.
EDIT
I've quickly looked into running LaserGRBL on Linux & it appears that it can but it won't generate the G-code file for cutting, that still needs to be done in Windows, so it appears to be a non-starter.
Last edit: 11 Apr 2026 06:00 by Magpie.
11 Apr 2026 07:36 #3 by jon.in.swansea
Replied by jon.in.swansea on topic A new operating system
As someone who has been running various Linux & Mac mostly for years with the odd hours on Windows...
I have gradually moved to running Windows (W10 mostly) as a 'virtual computer' on my Linux or OSX main
computers.  Within that virtual instance of Windows I do the few things that only work on W.
Installing W is essentially the same except that I don't tend to register the W or tell it I have a MS account.
Once up and running I use the virtual machine software to make a 'clone' of the working Windows and put that
huge file somewhere in case W gets corrupted or MS changes the rules of the game.
Virtual W is slightly slower.  It takes up disk space but for the 95% of the time I don't need it, it is not running.
It is minimal hassle getting files between the Windows and the main operating system your computer normally runs.
The virtual W does not have to be connected to the web, or can be connected only briefly.
Might be something to talk to you Linux savvy friends about.  There is some investment of time getting
used to Linux (just as there is getting used to a new 3D printer or getting used to a different Tx.
For context: Most of the time the 'virtual machine' software I use is called "Parallels" and I use it to host guest W10 and Linux
operating systems on my Mac.  There are several free virtual machine software options for a computer running Linux to
host Windows.  But you can flip the idea... if you want to 'explore' Linux you could setup of Linux virtual machine on
your W computer and see what that is like.  If it irritates you then you can get rid of it and try a different Linux.
11 Apr 2026 07:55 - 11 Apr 2026 07:56 #4 by Eric
Replied by Eric on topic A new operating system
I have W11 on my main machine, and linux on a lappie. Don't like linux, as it seems counter-intuitive, but it doesn't carry all the junk that W does!
Mind you, I'm biased. Ive been using W in all it's iterations (except 8 ) ever since 95 - and a bit of DOS on a clockwork amstrad!
Last edit: 11 Apr 2026 07:56 by Eric. Reason: typo
11 Apr 2026 09:04 #5 by Magpie
I bought this W11 machine because the graphics card I bought for my Flight Simulator wouldn't work on the W7 machine, otherwise I would have just stuck with it.
My M.O. is to design the part on LibreCad then export it as an SVG file which I then pick up in LaserGRBL, & there I save it as a G-code file. I then transfer it to my W7 machine for the cutting. When it is saved in LaserGRBL the feedrates and laser intensity are set in the F & S values. Before the burn I set the S value down to S100 in notepad to prove the program then up it to the cutting value. I can also turn the feedrate down if something is not right & see where it is happening as the laser scampers all over the place & not in a predictable order.
To get the SVG & G-code files into the W7 I can either carry it down on a USB stick or email it to myself there.
I program my Raspberry Pi in Ubuntu. It is abit peculiar but I was reared on DOS & have done machine code & android programming in the past so it is quite nostalgic.
11 Apr 2026 10:40 - 11 Apr 2026 10:42 #6 by Klipkopwildlife
Replied by Klipkopwildlife on topic A new operating system
Okay so my new machine is a B650 with an AMD 7 series processor running at 5Gb/sec. 16Gb ram, Nvidia GT 1050 graphics card and 1 Terrabyte of SSD.
After my initial failure with Linux I decided to re-load Windows 10 which I got for free at Microsoft (and put on a USB stick) but then I had to buy an Activation code for a fiver since none of the 3 other codes would work. Once up and running I discovered that Windows ran just fine but startup time was ridiculously long, even after loading the machine drivers.
I then discovered by accident that Linux will quite happily on coexist and run the same machine as Windows. Apparently the same cannot be said if you do it the other way around!
I put Linux Mint Cinnamon on a stick and switched on with the stick plugged in. Bingo, Linux started, eventually and I was able to assign 250Gb for Windows and 750Gb for Linux. You have to wait a long time before telling the front page to "Install Linux" it won't be rushed, one of the many mistakes I made.
Last edit: 11 Apr 2026 10:42 by Klipkopwildlife.
Thanks: Flytilbroke, Quorneng, jon.in.swansea
12 Apr 2026 10:42 #7 by Klipkopwildlife
Moving on, one of the things I didn't realise is that Linux Mint stores any new stuff that you've downloaded and installed in RAM, not on the hard drive. You must do a 'restart' for it to transfer the programs etc to the hard drive. You are told to do this in the instructions, but only once, you need to tell me about 10 times before it penetrates my thick skull! If you switch off instead of Restart what you installed in the last session is gone!
Once you've installed the program/s they're in the Software manager, along with about 60,000 other programs! Which is okay for stuff you don't use often, Firefox comes pre-installed but imagine having to search for Thunderbird every time you want to use it!
Luckily programs can be 'pinned' to the task bar.
So far I've got Blender, VLC, Google Earth, Open Office (Linux version), FreeCAD and Cura up and running on the task bar
Thanks: Eric, Flytilbroke, jon.in.swansea
12 Apr 2026 17:41 #8 by Klipkopwildlife
It took the whole day because it grabbed 1.6Gb of space but I now have Prusa Slicer on my tool  bar
Thanks: jon.in.swansea
12 Apr 2026 19:00 #9 by Eric
Well - I read the words!  :-)
14 Apr 2026 12:19 - 14 Apr 2026 12:19 #10 by Klipkopwildlife
To add to Blender, VLC, Google Earth, Open Office (Linux version), FreeCAD and Cura I now have Thunderbird, Prusa slicer and PlayOnLinux up and running on the task bar.
PlayOnLinux is a very clever application that runs any Windows program for you, when I learn how to use it!
Something else I've discovered, the Windows 10 that I have is clearly visible as another folder on the Linux so I can more files across at will.
Last edit: 14 Apr 2026 12:19 by Klipkopwildlife.
Thanks: Eric, Flytilbroke, Quorneng, jon.in.swansea
15 Apr 2026 07:04 #11 by jon.in.swansea
There is another tool to put on your Linux computer.... TIMESHIFT.  It allows you to get your computer back to some prior state e.g. before you made it just a bit more perfect....
It is a fast backup system - plug in an external disk that is a bit bigger than your internal drive, click a few options and it will backup your files.  Similar to Windows system restore.
It can be driven via a command line or there is a graphic interface (which I use).
First time it copes everything, subsequent runs it only copies files that have changed.  You can set a schedule, mostly I just run it manually.
Each 'shapshot' is in a folder named after the date, in that is the OS and your 'home' folder and files. If you want to recover your Linux computer to a prior state it brings up a list of 'shapshots', select it and go and make a coffee.
If the external disk starts getting full you can delete older 'snapshots'.
A summary can be found at:   computingforgeeks.com/timeshift-backup-restore-linux/
15 Apr 2026 18:38 #12 by Klipkopwildlife
Thanks Jon, that's a major step, I've set it to take a daily, weekly, and monthly snap shot but since that's on the existing drive it's not much help if the SSD goes tits up!
17 Apr 2026 07:17 #13 by jon.in.swansea
Surely you have some spinning rust somewhere in your collection of shelves in the workshop? But not one of the 5 1/2" floppy drives that would be seriously slow....
17 Apr 2026 12:08 #14 by Klipkopwildlife
It turns out I have Timeshift already running but backing up to the M2 SSD, I can't find out how to change the storage drive to the 2Tb hard drive I've connected, my computer says it's mounted!
17 Apr 2026 12:17 - 17 Apr 2026 12:19 #15 by Eric
toolbar at the bottom of your screen - look for the little chevron pointng up. Put your cursor on that, and you get a pop-up saying something like hidden icons. Click the chevron, and you get a new box showing a few things. Look for the one like a little thumb-drive, click that, and it should give you a selection of drives in the machine. Pick the one you want, click it, then you have deselected - unplug it, wait a few then plug it in again, and the puter should find it.
Last edit: 17 Apr 2026 12:19 by Eric. Reason: typo
Time to create page: 0.698 seconds
