Electrickery
04 Oct 2026 18:47 #1 by THE BLACKBIRD
Electrickery was created by THE BLACKBIRD
I have a new lipo charger that tells me the lipo is fully charged
And a new battery checker that reads the the same lipo is at 4%
04 Oct 2026 22:55 #2 by Eric
Replied by Eric on topic Electrickery
Are they old batteries?
If they are new, you have a setting wrong somewhere.
05 Oct 2026 10:56 #3 by THE BLACKBIRD
Replied by THE BLACKBIRD on topic Electrickery
Everything is new, the settings are ok
05 Oct 2026 10:57 #4 by Klipkopwildlife
Replied by Klipkopwildlife on topic Electrickery
I'm guessing the 2S/3S/4S/5S setting is wrong in the charger, it's usually the last one that gets set!
05 Oct 2026 10:58 #5 by Klipkopwildlife
A picture of the charger please Tony
05 Oct 2026 18:10 - 05 Oct 2026 18:19 #6 by THE BLACKBIRD
Cannot find the instructions so iv been on YT and found 3 vids, one in tagalong 1 in Indian and the other silent
Its set up ok i think
And it works for 15-16 seconds and then cuts out saying it is full
The checker still says 4%
 [attachment=31580]IMG_2443.JPG[/attachment
And on my three 4s lipos it just say connection broken before even starting
Photos in the wrong order
You dont get this with a DLE
Last edit: 05 Oct 2026 18:19 by THE BLACKBIRD.
05 Oct 2026 22:33 - 05 Oct 2026 22:36 #7 by SimonC
Replied by SimonC on topic Electrickery
I use very similar 4 button chargers and from your pictures I can't see anything wrong with the way you have it connected and the screen info looks correct.
I can only think of two scenarios.
If when using another charger the cells take a reasonable charge then that B6V3 is at fault.
If that LiPo does not charge on any charger than the one (or both) cells are kaput!
Just point
On both my 4 button (they have exactly the same button headings) when the charger is actually charging if you press the RH "setting" button the display changes to show the individual cell voltages during the charge via the balance plug.
The charging dplay
The display after pressing the RH Status button
Pressing the button cycles between the two displays
If you charger does the same it shows what the charger thinks the cell voltages are rather than the battery total.
On my chargers I cannot find any parameter I can set that would cause the charger to stop at 10.44V when on a 3s LiPo setting.
I hope this helps
Last edit: 05 Oct 2026 22:36 by SimonC.
06 Oct 2026 02:24 #8 by THE BLACKBIRD
Yes my charger is the same when pressing that button
06 Oct 2026 07:17 #9 by Eric
This might be BB's problem -
06 Oct 2026 07:27 - 06 Oct 2026 07:43 #10 by Eric
or a slightly older model - probably the same circuit board inside -
Last edit: 06 Oct 2026 07:43 by Eric. Reason: checked the url because it replayed a blank black square!
06 Oct 2026 07:34 #11 by Eric
Perhaps this one is the one that BB found, with no commentary - note there is no holo sticker on the charger, and the demonstrator can't even put a Deans plug and socket together correctly! -
06 Oct 2026 07:41 - 06 Oct 2026 07:45 #12 by Eric
or this one, this guy says and shows what he is doing, and what the display reads.
Notice that the balance socket(s) have different ones for different sized batteries. Plug into the wrong one, and the charger will tell you no connection! Is that what BB did?
loads more, if you put the charger name into the search box.
Last edit: 06 Oct 2026 07:45 by Eric. Reason: added a comment
06 Oct 2026 09:38 #13 by THE BLACKBIRD
Turned it on this morning set it to storage charge and its working
Have to play around with it a bit more
06 Oct 2026 12:06 #14 by Eric
Nought point two of an amp? That's going to take a heck of a long time to charge the battery!
06 Oct 2026 13:43 #15 by THE BLACKBIRD
Indeed Eric 239-59 minutes the lipo is 11-27 and the cellls read 3687   3770   3770
So i connected the 4s ones and all i get is connection break
Time to create page: 1.037 seconds
