How to land. (Landing Procedure)
- admin
- Make it count!
I know there may be differences depending on the type of model ect.
What realistic advice would you give to a beginner wanting to learn to land?
This is the commitment. You dont have to take off, you dont have to fly, but when you have done the first two, then the landing is a commitment, in other words , you have to do it. It is the most difficult thing to do for a newcommer.
The only way I have found success is to teach the pupil to do slow fly by s over and over again till they are not scared of being near the ground. As they get lower and lower, with throttle, not elevator, until they are at the stage of being a foot from the ground, then the command close throttle will put the model down gently on the deck.
In my flying, I always use the four point method. 1 fly past yourself into wind at normal flying speed, and travel 150 yds at about 100 ft. turn 90% and reduce throttle slightly fly maybe 100 yds and turn 90% again, reduce throttle slightly again. This will cause the model to drop slightly. Turn again, now you are going downwind, and continue until level with where you started from, ie this is the 3rd leg of the rectangle. Turn 90% again and you have finished at the point you started at, but much lower. Line up the model and fly it into wind again and reduce throttle all the time, and control the height with throttle, and as model come to 6 inch above the ground, feed in elevator to flair out the model, which should then alight gently on its wheels. Allow it to slow down, then use rudder to steer it towards the pitts. Job done. Always remember throttle controls height, elevator controls speed.
- Phil Wood
You surprise me son, You're a pretty damn good flyer & an excellent forum creator, but you knock yourself.admin wrote: For the benefit of any newbies I would like use to go through the basics of landing a model.
I've seen expert flyers shit themselves in combat when you've come howling in for the kill ... you just have a natural flair for the hobby.
Don't ask how to land, .... tell everyone how you learned to do it. :silly:
- kamco kid
- has anyone found my marbles?
I don't think Mike's knocking himself Pol, I think He's thinking of newbie flyers joining the ranks. (am I right Mike?)
Everyone has their own twists same as each model has it's own quirks.
One thing's for certain as Garry said earlier.. once you're up, you're committed to a landing of one kind or another.
Rich
The Beard wrote: Sometimes when critical alfa male is at the field I keep flying around wanting to land but wait until he is doing something because he can be very intimidating.Its so peaceful when he is not there.
Best thing is to ban him, if that cant be done, find when he goes, and go on different days to him.
After meeting you Stephen, it suprises me that he CAN intimidate you. He certainly wouldnt have that effect on me.
- Sarah-Jane Smith
- Gone
- Thank you received: 2182
Is this topic in the " how to learn" section? do we have a "how to learn" section?
Have landed a helicopter, albeit it was more a erm weeeeeeeeeeeeeeeeeeeeeeeee splat but it ended on the ground so guess object fulfilled :woohoo:
Was advised to get a tricycle undercarriage for my first plane - does this help make landing easier?
- Sarah-Jane Smith
- Gone
Wing incidence, the way the wing is tilted - fore and aft.
Positive incidence, (front higher than back) lifts upwards.
Negative (back higher than front) 'lifts' downwards!
Very crude explanation.
- blue123
- Thank you received: 146
