Fuel proofer?
  • Del Piero
  • Junior Member
  • Junior Member
22 Jan 2020 09:54 #1 by Del Piero
Fuel proofer? was created by Del Piero
Hi!
What are you guys using as fuel proofer on diesel powered models please?
I have tried a couple of varnishes, but they always seem to bubble up.
Many thanks,
Del Piero.
22 Jan 2020 10:06 - 22 Jan 2020 10:20 #2 by paul d
Replied by paul d on topic Fuel proofer?
Regular cellulose dope is diesel proof so is enamel and polyurethane.
It's only the either that's aggressive and that evaporates like mad! As long as the model is protected against the soaking in oil it will surely get you'll be ok.
Oh btw enamel is ok over dope if your painting some decoration but don't try it the other way round!!!
hope that helps...
I think I'm the only one here that uses diesels? dying breed!
Last edit: 22 Jan 2020 10:20 by paul d.
  • Del Piero
  • Junior Member
  • Junior Member
22 Jan 2020 10:21 #3 by Del Piero
Replied by Del Piero on topic Fuel proofer?
I was essentially thinking of Solartex covered models, but thanks for the advice.
Del Piero.
22 Jan 2020 10:24 #4 by paul d
Solartex is fuel proof on its own....
22 Jan 2020 10:59 #5 by Eric
Replied by Eric on topic Fuel proofer?
Not always, Paul.
Depending on how it was applied, oils can seep in between the fibres. Even if it cannot penetrate the dye layer, it gets trapped in the weave, and very soon looks mucky.
  • Del Piero
  • Junior Member
  • Junior Member
22 Jan 2020 11:05 #6 by Del Piero
I agree.
It really needs something, as it soon looks very messy.
I've tried Ronseal silk outdoor varnish and Wilko outdoor varnish.
On both models, this has bubbled up, particularly around the engine bay and undercarriage, hence my enquiry.
Del Pero.
22 Jan 2020 11:48 #7 by paul d
Tex is fuel proof, granted oil can get in the weave ( scrubs off with warm soapy water) if you want to completely fill the weave then it needs filling, try enamel although the weight will build up..
22 Jan 2020 14:44 #8 by Quorneng
Replied by Quorneng on topic Fuel proofer?
It is worth remembering that the 'nitro' element of glow fuel is the main constituent of all effective paint removers. Its use in paint removers is now banned in the UK.:ohmy:
Even polyurethane paints suffer over time hence the importance of removing all traces of nitro glow fuel after flying. Not easy if the covering itself is porous. ;)
22 Jan 2020 15:08 #9 by paul d
Del was asking about proofing against diesel Q :P
22 Jan 2020 15:31 #10 by Quorneng
Oooops!
Sorry, should have gone back to the original post.
22 Jan 2020 17:26 #11 by Klipkopwildlife
Replied by Klipkopwildlife on topic Fuel proofer?
However it's a perfectly relevant comment since some commercial diesel fuels do have a small nitro content. And it's useful to know!
22 Jan 2020 19:14 #12 by old fart
Replied by old fart on topic Fuel proofer?
Maybe the two-part fuel proofer for example Aerokote might be a better choice.
22 Jan 2020 20:55 #13 by paul d
Klippy, model technics ( fuel I use) has no nitro...
22 Jan 2020 23:08 #14 by Quorneng
No nitro but according to Model Technics it does contain Isopropyl nitrate which when burnt will, to quote, produce irritating, corrosive and/or toxic gases.:ohmy:
Just as well its only at 2% concentration in the fuel.
23 Jan 2020 09:02 #15 by Flytilbroke
Replied by Flytilbroke on topic Fuel proofer?
Paul, you are nor alone in enjoying the smell and lovely oily models. I have four little ones. love them.
I have used dope and some times polyurethane varnish as proofer.
Thanks: paul d
Time to create page: 0.990 seconds
