- Thank you received: 14
1st time builder-Dumas kit 210 Ford Trimotor Need help with wire landing gear
- MiamiMan
- New Member
I can't for the life of me figure out how Wire A is supposed to fit, not to mention wire B.
It says to cover all parts and then cement the wing onto the fuselage, and THEN drill a hole into the wing for Wire B.
11/16 in from the dihedral break (which I can't see) Am I supposed to drill through the tissue??
At this point I am completely befuddled and could use a helping hand.
Thanks.
- Thank you received: 14470
Myself, I've never seen any Dumas kit, but reading between the lines, I would hazard a guess that this model is a pretty small free-flight one.
The best I can suggest is that you do a computer search for a full-size Tri, and see if you can see where the wires go, such as -
www.google.com/search?q=ford+tri-motor+i...imgrc=zVkzvwkqRLOyfM
- MiamiMan
- New Member
- MiamiMan
- New Member
- MiamiMan
- New Member
I made the A&B parts full size but out of easy to bend copper wire.
You will obviously need two Bs, one for each side.
They are joined like this. I would suggest solder if possible.
Note B and the front strut lie parallel to each other which make assembly a bit easier.
Finished, on one side, the wire should look like this.
I don't know how the undercarriage parts are actually fixed to the air frame.
Peanut scale is a bit small for me.
My only attempt was an Andreason BA4b converted to electric well over 50 years ago.
- MiamiMan
- New Member
- MiamiMan
- New Member
Thank you for going out of your way to take pics of your work.
- MiamiMan
- New Member
There's a tutorial on here somewhere, but right now I don't have time to look for it, I'm in the middle of cooking the evening meal!
- MiamiMan
- New Member
- MiamiMan
- New Member
Wow! That looks like an immensely thick (scale?) wing section.
At very small sizes the normal rule is that a thin wing section reduces drag well in excess of the loss in lift. One reason why 'shockies' with their 'flat plate' wings fly so well.
