Made the leap to IC
08 Jun 2021 18:47 #16 by Klipkopwildlife
Replied by Klipkopwildlife on topic Made the leap to IC
Ok, the tightness at the top of the stroke is standard for an ABC engine. It looks as though a gudgeon pin circlip broke which has caused the scoring. In my opinion this engine will be very down on power and will be reluctant to idle very well. You should be able to find a piston and sleeve set on flee bay which will restore the power.
Thanks: squareflux
08 Jun 2021 19:39 #17 by paul d
Replied by paul d on topic Made the leap to IC
oh that's a shame..I agree with the others..it's scrap sadly although ripmax do still have a few Irvine spares...when your ready give me a shout, I'm sure I can find you a good engine, I've got a few oil soaked contacts!!!
08 Jun 2021 23:06 #18 by Eric
Replied by Eric on topic Made the leap to IC
It looks like my last post and Square's photo's crossed - I was typing as he replied, so my comments were superfluous! :P
09 Jun 2021 10:01 #19 by Flytilbroke
Replied by Flytilbroke on topic Made the leap to IC
I am pleased you made that decision. It is not just the possible loss of a model but any consequential damage as it hits (lands) that is of concern. I think you will do ok as a model flyer.
Thanks: squareflux
  • squareflux
09 Jun 2021 18:20 #20 by squareflux
Replied by squareflux on topic Made the leap to IC
Flytilbroke wrote: I think you will do ok as a model flyer.
I hope so :D
Just for some context, I'm 44 now. I used to go to my local model flying field when I was my son's age (11) and wish I had my own to fly. I'm only now at a point in life where I have the money, space, and time to be able to get into this hobby. So I suppose that explains why when I went to the flying field aged 11, it was all "old" guys :D
10 Jun 2021 08:49 #21 by Klipkopwildlife
squareflux wrote: I'm 44 now.
Still a whippersnapper then.[badass]
There has been so much bad press about MDS, I have a brand new MDS 40 here that I bought from Beard, many years ago. I never trusted it to a model, I've just checked it, I can turn the crankshaft with my fingers! I wonder if they didn't factory run them before shipping, so it's still got the original assembly oil in it. I would believe that the good manufacturers discard as many as 20% of production after test running.
You can buy any of the following with confidence, OS, Enya, Saito, ASP, Paw, SC and Thunder Tiger. Paul Heckles told me he only uses Magnum, uses them for a year and then chucks them.
For the President I would seriously look for a 46, they're generally on the same crankcase as a 40 and even a seriously second hand one will out perform a 40.
Thanks: squareflux
  • squareflux
10 Jun 2021 20:12 #22 by squareflux
I'm watching an SC 46 on fleabay at the moment, as I was thinking a 46 would be better as well.
11 Jun 2021 08:27 #23 by Klipkopwildlife
squareflux wrote: I'm watching an SC 46 on fleabay at the moment, as I was thinking a 46 would be better as well.
Good Lad, nice move.
Thanks: squareflux
01 Sep 2021 06:37 - 01 Sep 2021 06:41 #24 by Happy Wanderer
Replied by Happy Wanderer on topic Made the leap to IC
I'd agree with Eric here. The Irvine .40 might struggle a little. The T180 is a large draggy model, and although it's undoubtedly a sound design which flies very well, it does need sufficient power. The one in my shed - from a deceased flyer's collection - has an Enya .53 four stroke, which flew it nicely, although did not have oodles of power to spare due to the bulk of the model. The sizeable cowl can kill a bit of the thrust from smaller engine/prop combinations. I'd go with something capable of turning a 12 inch prop with authority as a minimum. A large-ish draggy model with just enough power is not a good combination......
Last edit: 01 Sep 2021 06:41 by Happy Wanderer. Reason: Added more text.
Thanks: Eric, Klipkopwildlife, squareflux
  • squareflux
01 Sep 2021 06:41 #25 by squareflux
Thanks. I ditched the Irvine as the cylinder head bolt holes were cracked, and I'm now using an SC 46 that runs well on the test stand.
As I'm a beginner, I'm happy for it to be a slow and gentle flyer for now. My son will also be using it to learn. If I want a bit more speed, I can change the engine for something bigger later on.
01 Sep 2021 08:11 - 01 Sep 2021 08:11 #26 by Eric
Put the bigger engine in now, and use the throttle!
An underpowered model is going to be crawling around the sky on the ragged edge of stalling - not a good learning experience!
It's a bit like putting a car engine into a truck, and expecting it to go uphill!
Last edit: 01 Sep 2021 08:11 by Eric. Reason: added a comment
  • squareflux
01 Sep 2021 09:18 - 01 Sep 2021 09:19 #27 by squareflux
Hmmm, time to get on flebay then. I visited a local club recently, and someone there that had a T180 grimaced a little when I said I was using a 46, and said it might be ok. Better safe than sorry I suppose.
There were also some engines in the collection that the hobby shop as selling that I got the Aerovan from, so I'll pay them a visit later.
Last edit: 01 Sep 2021 09:19 by squareflux.
  • squareflux
01 Sep 2021 10:49 #28 by squareflux
I was thinking following the chat here, to go for a 60 engine for my T180. The guy at the club I spoke to also mentioned that would be a better fit.
But would a Super Tiger G75 be too much? Got my eye on one, that's also got a dustbin exhaust to fit in the cowl.
01 Sep 2021 10:53 #29 by Eric
Although I'm talking electric here, My old Tundra would leap into the air and go vertical for a long way on a 3S 2200 lipo. A new guy turned up at the club with an identical model, but he was using lithium ion batteries, same cell count, but lower voltage, roughly the same weight, same motor and prop.
I was asked to maiden it, and after the usual checks (left really is left, etc) it barely crawled off the ground at full chat - well down the runway (a bit like a Cessna 150 with a tub of concrete on board!) - the slightest hint of up ele and it put it's nose down!
After staggering it round the circuit, getting no higher than about 40 feet, I flopped it back onto the ground by throttling back a bit!
He was going to buy some lipo's!
  • squareflux
01 Sep 2021 10:58 #30 by squareflux
Yeah, good point, and if I thought about it I've experienced the same with foam electrics I've built in the past. I couldn't work out why one always wanted to prop hang, until I changed the battery down to less power :lol:
I suppose it's just a question of fit and weight for the model.
Time to create page: 2.714 seconds
