- Thank you received: 22
PAW compression screw thread.
- box
- Junior Member
29 Jul 2022 08:40 #1
by box
PAW compression screw thread. was created by box
Hi!
Can anyone tell me what the thread is, on PAW engine's, compression screws, please and are they all the same for all their engine sizes?
Thank you,
box
Thank you,
box
- Thank you received: 14470
29 Jul 2022 10:08 - 29 Jul 2022 10:11 #2
Replied by Eric on topic PAW compression screw thread.
Depending on where you are - call in or drop them a line! -
www.eifflaender.com/
Last edit: 29 Jul 2022 10:11 by Eric. Reason: changed the url
- Thank you received: 10844
29 Jul 2022 12:01 #3
Replied by THE BLACKBIRD on topic PAW compression screw thread.
Or message Paul on here he will know
- box
- Junior Member
29 Jul 2022 12:35 #4
by box
Replied by box on topic PAW compression screw thread.
Sorry, Paul who?
29 Jul 2022 13:50 #5
Replied by Quorneng on topic PAW compression screw thread.
box
It appears that the threads on PAW engines are, or were, BA (British Association number sizes) except the compression screws which were likely a 'special' larger diameter fine thread. Even if you had a PAW engine it might be difficult to establish the true thread characteristics (diameter, TPI & thread angle) without some engineering thread gauges.
I would have to agree with Eric the best bet is to contact PAW direct. The company is still run by a descendent of the founder.
- box
- Junior Member
29 Jul 2022 14:09 #6
by box
No probs. Tony replied as follows:
The size is 2BA, all engines are the same with the exception being the 60 which is 1/4 UNF.
Thanks for your help. box
Time to create page: 1.027 seconds
