Precedent T180
  • The Beard
07 Jun 2013 20:09 #1 by The Beard
Precedent T180 was created by The Beard
I purchased one of these on E Bay,never flown and very well constructed.Its fitted with a Laser 90 which I couldnt resist buying seperately but still in the model.I heard from Steve Webb Models that they have a glow start extension which I need to fit before I can start the engine.If it arrives in the post tomorrow I hope to have it ready to fly on Sunday.Ive just discovered its Warbirds this Sunday and Ive still not readied Tonys Hurricane number 3
  • The Beard
10 Jun 2013 04:27 #2 by The Beard
Replied by The Beard on topic Precedent T180
Im hoping the start glow kit from Steve Webbs arrives Monday so I can get the T180 prepped for flying doesnt need mu8ch.A battery,Rx should see it ready.
  • The Beard
10 Jun 2013 21:25 #3 by The Beard
I chased the postman round the block and managed to rugby tackle him and get my Steve Webb package from him.So Ive soldered the glow connection adaptor to get the lazer started.I connected up and found the throttle seized.WD 40 was aloud to soak in and whilst putting a heat gun on the seized area and working the servo it quickly was working.Had to remove the cowl but that was neat and straight forward.So the cowl was soon refitted and the on board battery which is buried somewhere is on charge and will need checking before a flight is attempted
Thanks: Dean M
  • Dean M
11 Jun 2013 09:09 #4 by Dean M
Replied by Dean M on topic Precedent T180
I like these, look forward to hearing how it flys.
I keep looking at the T240 on SLEC's website hmmmmmmm
I nearly choked on my latte.
11 Jun 2013 10:17 #5 by Grumpy42
Replied by Grumpy42 on topic Precedent T180
The Beard wrote: I chased the postman round the block and managed to rugby tackle him
You did???? Oh come on mate, even Garry and I tried to catch him and he got away! :woohoo: :woohoo: :woohoo: :evil: :evil: :evil: :whistle: :whistle: :whistle: [badass]
  • The Beard
11 Jun 2013 19:53 #6 by The Beard
I was in a car Grumps,and he was on foot.Ive had the Lazer engine running but need help.The needle valve isnt held by a clip like usual and there is an adjuster screw the other end.But to get the engine running,i blew down the fuel nipple until I could hear it hissing.It started and by unscrewing the needle valve I got it revving,Cant get it to tickover.Its been standing for years so tomorrow Ill run fuel through it and keep it going for a tank full see if it clears it out.
11 Jun 2013 21:06 #7 by Eric
Replied by Eric on topic Precedent T180
With Lazers, I think you will find the needle is the main jet, and the screwdriver one is the idle mix. You will find it very tricky getting it somewhere near right, but once sorted, it should never need tweaking again.
Get it running reasonably rich at half throttle, then ease the idle screw in a FRACTION, then carefully close the throttle, listening to the engine. If it hunts it is probably too rich, and if it fades, it is too lean. (but it might also be WAY too rich!)
There was a guy fiddling with one at Halton, on Sunday. It took him all day to get it something like right.
  • The Beard
11 Jun 2013 21:56 #8 by The Beard
Thanks Eric are you saying I still screw the needle valve as usual
11 Jun 2013 22:07 #9 by alan cantwell
Replied by alan cantwell on topic Precedent T180
Is it a super tiger, or an irvine carb? if its an ST, and its the early wire needle, then there is a clamp nut that keeps it from turning, if this is not nipped up, then the needle will rotate at revs
11 Jun 2013 23:21 #10 by Eric
Yes, Beard, the needle controls the full-speed mix, and the screwdriver one the idle mix. So you set the needle as normal. BUT each time you adjust the idle jet, you need to reset the main needle, too, that's why it is so fiddly.
Thanks: The Beard
  • The Beard
12 Jun 2013 19:36 #11 by The Beard
I did buy this engine as a 90 and its a 50 bit miffed
  • The Beard
12 Jun 2013 23:40 #12 by The Beard
The Laser 50 was made between 1988 and 1990.I think its over propped with a 14 x 5 and believe an 11x6 might be better suggestions gratefully received .I think the main needle valve is lock nutted so that would make sense
  • The Beard
13 Jun 2013 20:47 #13 by The Beard
I fitted a 12x6 and opened the bottom adjuster 2 clicks.I started the engine,it runs perfectly tickover is very low and revs to peak perfectly,very pleased.
  • The Beard
13 Jun 2013 20:48 #14 by The Beard
:woohoo: :woohoo: :woohoo: :woohoo: :woohoo:
  • The Beard
14 Jun 2013 01:31 #15 by The Beard
Tomorrow I can check the cofg and its then ready for its maiden.Just waiting the weather
Time to create page: 0.943 seconds
