What's a good 4 stroke sport engine?
- Phil Wood
I've only ever flown models with 2 stroke engines, but I think I'll go for a decent 4 stroke so I need a bit of advice.
Many years ago, when I was a lad, O.S. engines were not high performance, they were the poor man's sport engine. Now it looks as if things have changed & O.S. seem to have the best reputation there is..... Do I really need to go for O.S. in order to get a decent 4 stroke?
The model is likely to be a low wing aerobatic sport model, 56 inch wing span, weighing about 5 - 6 pounds.... but I do want it to have some guts.
I've done a bit of window shopping & I've got some idea of how many bills I'll have to leave to buy a suitable engine.
Now the O.S. prices are pretty much the same wherever you shop .... I'm not talking about saving the odd couple of quid, just the general ball park.
I like shopping at HobbyKing & I've had no complaints up to now, but HK only do ASP 4 strokes so I'd like to know if they're any good?
They are a lot cheaper than O.S.
Here's an example www.hobbyking.com/hobbyking/store/__8985...oke_Glow_Engine.html
I'm not overly impressed with the performance figures ... the model I'm describing would probably fly on a 40 size 2 stroke.... this is a 61 four stroke, but is still recommending an 11 X 7 prop & at best 11,500 rpm .... with a similar model on electric, I can swing a 13 X 6 or 12 X 7 at 10,500rpm .... but I'll leave that to the experts ( That's you lot ) :lol:
Is it worth the extra cash to go for an O.S. ... or are ASP a good brand?
Should I actually go for a bigger engine for a bit more grunt?
Can I please have a few general suggestions as to what to go for?
I will probably be flying this model each week in the evening, after flattening my lipo's flying with Garry during the day, but it could also very well turn out to be a modelchat club community model .... the sort you'll be allowed to fly if you happen to be passing our strip & don't have a model with you .... it could get a lot of wear & tear.
Please don't kick off the electric / IC debate ... just suggest a few engine alternatives & let me have your views on various engine manufacturers.
Cheers, .... Pol.
- Phil Wood
I heard SC were a good alternative .... but would I need more than a 52?The Beard wrote: SC 52 4 stroke
- Phil Wood
Even in the likes of Club 20 pylon racers .... a 20 size OS might rev at 15,000 rpm ... the likes of a Fox 20, ... Veco, ... or Webra, would push nearer 20,000 rpm .... far better for that class.
I can only assume that OS kept the faith & their determination has paid off.
I've bought a lot of second hand engines on Fleebay, I would say 50% are sold because they've been messed around by the owner and then the Club 'expert' then can be got right, but only by someone who knows what he's doing, and has access to a good source of spares.
SO, all this waffle, what does it mean, simple,
by chinese get a couple of seasons out of it, by one of the others i have mentioned, buy an engine, buy it for LIFE
alan cantwell wrote: then go OS/SAITO/ENYA,/LASER YS need expensive fuel,
Laser engines use straight fuel though Neil Tidey stipulates synthetic lube should be used.
K+B were fast, but VERY loud and fairly short-lived.
- Keith T
- Senior Member
- Thank you received: 114
I am in the process of deciding what to power it with and haven't decided on the IC/Leccy debate yet (don't intend to start that in this thread - keep to Pol's IC queery)
This is my first such build and I've only got experience with IC heli engines (and not much at that!), so I am frankly amazed at the variety of engines.
I too need this advice on what to get if I go down the IC route.
HF
With sufficient thrust, pigs will fly!
- Phil Wood
There are two possible models up to now.Garry Pollard wrote: As we have some very knowlegable peeps on here Pol, I think they need to know the model you have in mind to make a proper decision
One is an ARF from HobbyKing & the other is a part built one that I already have.
The HK one will save me a lot of work & is only £44.19 + p&p
www.hobbyking.com/hobbyking/store/__3406....html?strSearch=Soar
The one I already have is a Super Strider 56.
I've still got to make a set of wings for this one, plus I've already made a bit of a start on converting it to electric.
I haven't got a picture of it, but it's similar to the Soar in that it's a 56 inch span low wing sport model that I can have as trike or taildragger.
It may be a little heavier than the Soar because of the foam veneered wings & sheeted fuz, but it looks very strong & should take the wind well.
It has a very meaty heavy ply firewall which should happily take a gas guzzler.
