Antonov AN 124 Rusian
19 Jul 2019 20:45 #16 by paul d
Replied by paul d on topic Antonov AN 124 Rusian
How about a "dolly " for take off?
19 Jul 2019 21:03 #17 by Quorneng
Replied by Quorneng on topic Antonov AN 124 Rusian
paul d
A take off dolly would certainly solve one problem but it would preclude any flight from my local rough grass field. Even with big 'Tundra' size wheels there would be insufficient thrust to get the likely take off speed.
So far all I have built can be flown (and the maiden!) from there.
The most bizarre has been the DH Albatross which was hand launched on its maiden with it retractable U/C down and using the wheel wells as a finger holds and belly landed with the wheels up! :lol:
19 Jul 2019 23:24 #18 by one tenor
Replied by one tenor on topic Antonov AN 124 Rusian
Same solutionmaybe???
20 Jul 2019 00:50 #19 by Quorneng
OT
Yes hand launched retracts would be solution but the Albatross uses proper 6" 2 blade props which give sufficient thrust to handle the additional weight.
The AN124 U/C layout will need both retracts and flaps so would need evenl more thrust to handle the weight yet its 3" EDF props will generate no more than half that of the Albatross!
So far the only solution appears to be some form of hand launching cradle, what ever that might look like. :unsure:
20 Jul 2019 08:59 #20 by paul d
catapult ramp launch?
20 Jul 2019 13:43 #21 by Quorneng
Thanks Klippy? for the mod to the title.
My thinking so far is based on the Albatross hand launch method but do away with the actual undercarriage legs (there are 12 in total on the AN124 :woohoo:) and use simple spring loaded (or servo powered?) doors to cover the necessary hand launch finger holds.
There are 10 main doors to choose from so it should be possible to select a pair close to the CofG! ;)
20 Jul 2019 19:39 #22 by Eric
Replied by Eric on topic Antonov AN 124 Rusian
Slightly forward of would be better - then it would launch like a dart instead of trying to loop over your head.
02 Aug 2019 17:52 #23 by Quorneng
I have bought motors, ESCs and props to build this but the heating element and thermocouple unit required to repair my 3D printer have still to arrived. :( Getting one nacelle right and printing it has got to be the first task.
Despite its size I still favour a one piece wing as with the batteries, ESCs and rx carried within it there would only be 2 servo connections (elevator and rudder) required to assemble the plane.
The only question would whether having 'batteries in the wing' would allow a suitable CofG to be achieved - ballast not allowed! :woohoo:
02 Aug 2019 21:38 #24 by Eric
Ahem - point of order - -
First line of first post read - First I have no intention of building one in Depron or anything else.:woohoo:
No?? :evil: :evil: :evil: :evil: [badass] [badass]
02 Aug 2019 22:27 #25 by Quorneng
That statement was quite correct. At the time I had no intention of building one!
A further point of order - did my earlier post today actually state that I was?
It only says i had assembled a set of motors, ESCs and props!;)
07 Aug 2019 19:56 - 07 Aug 2019 19:57 #26 by Quorneng
Now my printer is back working I did some!
An all printed 'test' nacelle and pylon for the A124.;)
Of similar overall size to the A350 nacelle and built up the same way from 3 pieces along with the same drone motor and 3x3.5 4 blade prop.
It is however significantly heavier at 91 g compared to 70 g for the Depron clad nacelle of the A350.
Obviously it is simpler to make, you simply watch the printer ;) , but it takes 81/2 hours to print the 3 pieces and there will be four to do = 34 hours! :woohoo:
Needs a bit more "thinking".
Last edit: 07 Aug 2019 19:57 by Quorneng.
Thanks: Phil Wood, Eric, Klipkopwildlife, THE BLACKBIRD, crash happy
08 Aug 2019 12:49 #27 by Ralpharr2001
Replied by Ralpharr2001 on topic Antonov AN 124 Rusian
Superb design and print Q.
08 Aug 2019 23:23 #28 by Quorneng
Thanks Ralph.
Left to right a bit more development of the motor mount and pylon component.
Together nearly 9 hours printing and about the same 'fiddling' with both CAD and CURA! :woohoo:
Left weighs 21.6 g where as the right just 17.5 g. A 20% saving and it is significantly more rigid and stronger. :)
The 'killer' bit is the nacelle itself. It currently weighs a couple of grams more than the motor and prop. As most of its weight comes from the inner and outer skins there is not much I can do about it. :(
Although the AN124 will have a slightly larger span than the A350 it will have significantly more wing area, but then it will need to with 4 of all the electrics rather than 2!
Still thinking!
Thanks: Phil Wood, Eric, Klipkopwildlife, Flytilbroke, crash happy
09 Aug 2019 05:09 #29 by THE BLACKBIRD
Replied by THE BLACKBIRD on topic Antonov AN 124 Rusian
Could you make two of the motors dummies,
So instead of printing 6 [badass]
Ha its the little one ;)
09 Aug 2019 10:22 #30 by Quorneng
BB
Yes the A350 flies well enough on 2 but it is a very 'clean' air frame so it manages with a thrust at just 25% of its weight.
On the other hand the fuselage of the AN124 is for the same span considerably 'fatter', thus a bit heavier and rather less well streamlined. Add the drag of two dummy nacelles and I expect it would just not perform on a 25% thrust to weight ratio.
Even with 4 fans I expect I will struggle to achieve sufficient thrust to overcome the extra drag and weight of its 'portly' fuselage, hence my 'paranoia' about weight! ;)
Thanks: Phil Wood, THE BLACKBIRD
Time to create page: 1.963 seconds
