90 inch Lancaster
07 Feb 2012 11:48 #1 by Grumpy42
90 inch Lancaster was created by Grumpy42
Yep - I had to state the wingspan because us poor colonials are being up staged by dear old Mother England's upper crust landed gentry - who - they emphasise have 134 inches - hmmm - I hope it strangles them in all the electrical cabling that will be required to run their el@#$%&*tric motors. I might add that my Lancaster model has PROPER internal combustion motors - just like the real one.
Sh*t stirring aside, to start this thread I think it proper to at least give readers a glance at the plans - the other reason is they are the only photos I have yet - unless you want to see a pile of balsa sheets, ply, foam and 4 luvly Saito 30 4 strokes still in their boxes. Stay tuned.
Attachment not found
07 Feb 2012 12:01 #2 by Phil Wood
Replied by Phil Wood on topic Re: 90 inch Lancaster
It'll need all those engines to drag that fat wing section through the air .... it looks like a Clark Y ... ON STEROIDS!!! :lol:
07 Feb 2012 12:33 #3 by Klipkopwildlife
Replied by Klipkopwildlife on topic Re: 90 inch Lancaster
Sorry Mike, I'm a normal person myself, you're going to have to post a pic of those motors!:woohoo: :woohoo:
07 Feb 2012 15:01 #4 by Ex-Member
Replied by Ex-Member on topic Re: 90 inch Lancaster
yes, lets see the engines.
looks a nice size though.
cant wait to see the first bits of balsa come together.
11 Feb 2012 09:36 #5 by Grumpy42
Replied by Grumpy42 on topic Re: 90 inch Lancaster
Well Ladies, Gentlemen and fellow crazy scratch builders - herewith commences the build! Please remember that I really am building from scratch - no CNC - no kit - just me, a scroll saw, a craft knife and a heap of balsa and ply. The other factor is that is a fairly old plan and the designer uses a lot of foam and brown paper covering - SO - this idiot has to modify the plan, make a further rod for my back and build the whole damn thing from timber - redesigning the wing entirely, that means cutting ribs, designing a building spares - yep - carbon fibre - and generally sending myself round the bend - Yeah Poly, Tony and Eric - I know I'm probably already well round it. :P
So - the photos : -
The very first pieces of balsa
Starting the first fuselage side
Plans came with an instruction manual and photo of illustrious designer - very Helpful
More pics to follow:-
11 Feb 2012 09:46 #6 by Grumpy42
More photos: -
The first former in place
Fuselage with the two centre parallel formers fitted
Looking from what will be the front of fuselage
Next jobs are to fit the other main formers, the doublers and 1/8th balsa fuselage sides. Then build up the shape from contour formers, sheet and block. I'm also going to make the turrets and cockpit glass from patterns I'm making up. I use a vacuum gadget I built to make the see through bits.
11 Feb 2012 15:05 #7 by THE BLACKBIRD
Replied by THE BLACKBIRD on topic Re: 90 inch Lancaster
It looks a lightweight structure, good luck with the build, i think you need a bigger hammer ???
11 Feb 2012 15:31 #8 by Ex-Member
impressive sir, impressive.
its started off well and looks a nice build.
:cheer:
yeah i know i will be cheating with a cnc pack, but i will have to cut all the bits for the mk11 by hand.
now where are the pictures of these engines. :cheer:
11 Feb 2012 15:40 #9 by The Beard
Replied by The Beard on topic Re: 90 inch Lancaster
Well your way ahead of Tony already and it being underway already youve produced a well on the way fuselage,I have massive admiration for someone who scratch builds.I know how difficult a job it is.I realise that every time I put together an ARTF and think"who would bother with a scratch build"We have a Ripmax Lancaster in th club,taken the guy over 2 years so far and 18 months before that to arrive with loads od parts missing.Its cost over £2300 so far and still hasnt flown.
11 Feb 2012 16:56 #10 by Klipkopwildlife
Somehow the pics don't give a sense of scale, do they?
11 Feb 2012 19:29 #11 by Grumpy42
Klipkopwildlife wrote: Somehow the pics don't give a sense of scale, do they?
Good point Klippy - The fuselage is 59 inches long from front Bomb Aimers glass to rear turret. not as impressive as Tony's 8 footer I admit but still a fair size. Then again W/S is only a mere 90 inches - not 134. :P
Yes Tony - be patient - the motors all in good time. They are still in their boxes right now.
11 Feb 2012 19:33 #12 by Grumpy42
THE BLACKBIRD wrote: It looks a lightweight structure, good luck with the build, i think you need a bigger hammer ???
Well I do have a bigger hammer Tony but I hide it under the bench. :silly: The fuselage is quite a bit more substantial than those photos show. I haven't started putting all the bits on yet and what you see is only the box frame that everything else hangs off.
12 Feb 2012 04:48 #13 by The Beard
Itll be interesting to see how the fuselage progresses
16 Feb 2012 10:27 #14 by Grumpy42
Well Beard - the fuselage is progressing - not at the rate of BB's :( - but it is progressing. Should have the next set of build photos by tomorrow
16 Feb 2012 18:36 - 16 Feb 2012 18:39 #15 by Grumpy42
Well here we go - the next set of photos - now if I can just load them properly? :unsure:
Adding the fuselage main formers
Basic structure complete
Starting to add the doublers (full length each side!)
Last edit: 16 Feb 2012 18:39 by Grumpy42. Reason: Add text
Time to create page: 1.143 seconds
