90 inch Lancaster
- Grumpy42
Sh*t stirring aside, to start this thread I think it proper to at least give readers a glance at the plans - the other reason is they are the only photos I have yet - unless you want to see a pile of balsa sheets, ply, foam and 4 luvly Saito 30 4 strokes still in their boxes. Stay tuned.
Attachment not found
- Phil Wood
looks a nice size though.
cant wait to see the first bits of balsa come together.
- Grumpy42
So - the photos : -
The very first pieces of balsa
Starting the first fuselage side
Plans came with an instruction manual and photo of illustrious designer - very Helpful
More pics to follow:-
- Grumpy42
The first former in place
Fuselage with the two centre parallel formers fitted
Looking from what will be the front of fuselage
Next jobs are to fit the other main formers, the doublers and 1/8th balsa fuselage sides. Then build up the shape from contour formers, sheet and block. I'm also going to make the turrets and cockpit glass from patterns I'm making up. I use a vacuum gadget I built to make the see through bits.
- Thank you received: 10844
its started off well and looks a nice build.
yeah i know i will be cheating with a cnc pack, but i will have to cut all the bits for the mk11 by hand.
now where are the pictures of these engines.
- Grumpy42
Klipkopwildlife wrote: Somehow the pics don't give a sense of scale, do they?
Good point Klippy - The fuselage is 59 inches long from front Bomb Aimers glass to rear turret. not as impressive as Tony's 8 footer I admit but still a fair size. Then again W/S is only a mere 90 inches - not 134.
Yes Tony - be patient - the motors all in good time. They are still in their boxes right now.
- Grumpy42
THE BLACKBIRD wrote: It looks a lightweight structure, good luck with the build, i think you need a bigger hammer ???
Well I do have a bigger hammer Tony but I hide it under the bench. :silly: The fuselage is quite a bit more substantial than those photos show. I haven't started putting all the bits on yet and what you see is only the box frame that everything else hangs off.
- Grumpy42
- Grumpy42
Adding the fuselage main formers
Basic structure complete
Starting to add the doublers (full length each side!)
