The Cyprus LANCASTER
- Grumpy42
THE BLACKBIRD wrote: I think i will do a thredd on whats in my hanger.
Now that would be interesting BB. I'm sure I'm not the only one who'd be green with envy.
- Thank you received: 10844
im in a corner of the terrace and when i catch the pebble dash walls big chunks of balsa come of. :sick:
I shall be doing this one in fibre cloth and resin, harder to put on but a much better finnish than Poly C , and i have several 500ml bottles of Poly C left. :sick: :sick:
I can think of a way to use the tissue
i had fun fitting my fins as well.
i have a question about the wing boxes in the fuselage, how did you line them up square.
This show the wing with two coats of glass on it, half of it rubbed down, the shinny bit is not sanded and a prime coat of grey to show up any flaws, i will then rub down the prime coat until it is nearly completely gone then panel line it another prime coat light rub down then top coat.
dont know about rivets on here,
Im still trying to learn the art of finnishing i try different things on each one i do.
- Grumpy42
On another note some of the bigger ARFs are starting to look very attractive but I'll reserve judgement till I see how much trouble, if any, you run into with this one. I'd like to have a go at a twin turbine but two in the same model would destroy my wallet. Oh - and have a dip in the pool for me - all we have down here is freezing waters and white pointer sharks!!!
The back is still bad hope it go's before the end of August.
They say lightning never strikes twice in the same place, the dam wind here has stuck again this time the fuselarge took off the bench an finnished up 10m away with a hole in the top and gravel rash. and i had it taped to the bench in light of yesterdays event.
At least i know it flys first the wing and then the fuselarge
- Thank you received: 14473
