Radio Queen
04 Feb 2013 19:47 - 05 Feb 2013 09:07 #1 by Klipkopwildlife
Radio Queen was created by Klipkopwildlife
Ever since I saw Stephens I wanted one, so here we go.
First job is to pin the plan to a building board, and then use some plastic sheet to protect the plan. I've seen food wrap recommended but I can't get on with it. I use a thicker plastic, comes in 2M rolls for covering school exercise books.
Always start with the fuselage sides, it gives you confidence! Do not make the mistake of taking the first side off to build the second side! They'll be different if you do, build the second side on top of the first. This ensures they'll be both the same, but if you use cyanoacrylates (super glue) you must place a piece of plastic between the two halves! Otherwise you'll never get them apart! Ask me how I know! I use Aliphatic glue, it doesn't 'wick' too well so you can split the two halves later.
Last edit: 05 Feb 2013 09:07 by Phil Wood.
Thanks: Eric, Quorneng, THE BLACKBIRD, Sarah-Jane Smith
04 Feb 2013 23:31 #2 by Quorneng
Replied by Quorneng on topic Radio Queen
Klipkopwildlife
Is it the Radio Queen designed by Col HJ Taplin in the 1950 about 7ft span?
04 Feb 2013 23:35 #3 by Ex-Member
Replied by Ex-Member on topic Radio Queen
Nice looking build so far klip.
lots of work in an old timer isn't there.
05 Feb 2013 09:11 #4 by Phil Wood
Replied by Phil Wood on topic Radio Queen
Are you going to make this another FPV model to keep track over your animal sanctuary Klip?
05 Feb 2013 13:02 - 09 Feb 2013 12:31 #5 by Klipkopwildlife
Replied by Klipkopwildlife on topic Radio Queen
Quorneng wrote: Klipkopwildlife
Yup, he used it to make the first cross Channel flight.
This is the kit from Ben Buckle.
Last edit: 09 Feb 2013 12:31 by Klipkopwildlife.
05 Feb 2013 13:09 #6 by Klipkopwildlife
Polyphilla wrote: Are you going to make this another FPV model to keep track over your animal sanctuary Klip?
I see you pulled another 'allnighter' Phil! This was due to be the original FPV ship, then the I had to take time out to do some FPV demos for the Rhino people. That never happened when they saw what the price was going to be! Then, in a fit of idiocy, I managed to connect a 3s Lipo to the 3.3volt line of the FPV Tx and GPS! :angry: Don't ask, it's easy, I was too tight to buy the cables that Simon Dale supplies!
Anyway, short answer is yes! :)
05 Feb 2013 13:16 #7 by Klipkopwildlife
When you're ready, lift the unseparated halves off the board.
Now use a sanding block to make the outer surfaces absolutely identical.
Thanks: Eric, Dean M, Ex-Member, Quorneng, THE BLACKBIRD, Sarah-Jane Smith
05 Feb 2013 19:52 #8 by Grumpy42
Replied by Grumpy42 on topic Radio Queen
Interesting and very tidy build Klippy - BUT - what about the P38?? Any start yet??
06 Feb 2013 22:59 #9 by The Beard
Replied by The Beard on topic Radio Queen
This is an interesting build as I bought mine built.
07 Feb 2013 00:37 #10 by alan cantwell
Replied by alan cantwell on topic Radio Queen
My father told me he flew one of these when he was a lad, strangeley, he never showed any interest in my plane obsession while i was growing up, and only came with me once when i started flying R/C properly, after i had left home and married, nice to see one coming together
07 Feb 2013 03:08 #11 by The Beard
07 Feb 2013 04:33 #12 by Eric
Replied by Eric on topic Radio Queen
To copy a pic from photobucket - use the IMG code.
08 Feb 2013 15:03 #13 by Klipkopwildlife
Grumpy42 wrote: Interesting and very tidy build Klippy - BUT - what about the P38?? Any start yet??
I'm guilty of collecting plans of stuff that I'd like to be able to fly!
08 Feb 2013 15:09 #14 by Klipkopwildlife
I keep getting 'side tracked'! Because it's a 'beginners' build I keep realising that I'm using words and techniques that are not referenced elsewhere in the site, so I have to go off and do that!
I find this is the easiest way to do the splitting, but be careful, the blade is designed to break off, so don't apply too much pressure!
Two identical sides.
Thanks: Eric, Dean M, Ex-Member, THE BLACKBIRD, Sarah-Jane Smith
08 Feb 2013 15:20 #15 by Klipkopwildlife
Next, make the main formers, note how I've re-marked the main former that hold the engine bearers, I didn't want to be locked into one size/type of engine, so I've moved the bearers out 28mm and down 3mm. This is so I can use a piece of aluminium to mount different motors and set different side thrusts.
Now you can start fitting the formers to the main box structure.
Thanks: Eric, THE BLACKBIRD, Sarah-Jane Smith
Time to create page: 1.241 seconds
