Radio Queen
First job is to pin the plan to a building board, and then use some plastic sheet to protect the plan. I've seen food wrap recommended but I can't get on with it. I use a thicker plastic, comes in 2M rolls for covering school exercise books.
Always start with the fuselage sides, it gives you confidence! Do not make the mistake of taking the first side off to build the second side! They'll be different if you do, build the second side on top of the first. This ensures they'll be both the same, but if you use cyanoacrylates (super glue) you must place a piece of plastic between the two halves! Otherwise you'll never get them apart! Ask me how I know! I use Aliphatic glue, it doesn't 'wick' too well so you can split the two halves later.
Is it the Radio Queen designed by Col HJ Taplin in the 1950 about 7ft span?
lots of work in an old timer isn't there.
- Phil Wood
Yup, he used it to make the first cross Channel flight.Quorneng wrote: Klipkopwildlife
This is the kit from Ben Buckle.
I see you pulled another 'allnighter' Phil! This was due to be the original FPV ship, then the I had to take time out to do some FPV demos for the Rhino people. That never happened when they saw what the price was going to be! Then, in a fit of idiocy, I managed to connect a 3s Lipo to the 3.3volt line of the FPV Tx and GPS!Polyphilla wrote: Are you going to make this another FPV model to keep track over your animal sanctuary Klip?
Anyway, short answer is yes!
Now use a sanding block to make the outer surfaces absolutely identical.
- Grumpy42
- Thank you received: 14473
I'm guilty of collecting plans of stuff that I'd like to be able to fly!Grumpy42 wrote: Interesting and very tidy build Klippy - BUT - what about the P38?? Any start yet??
I find this is the easiest way to do the splitting, but be careful, the blade is designed to break off, so don't apply too much pressure!
Two identical sides.
Now you can start fitting the formers to the main box structure.
