- Thank you received: 10844
the Cyprus 50" F3A Practice model
I want to try and practice the F3A schedual as i dont like flying round and round like most of the warbirds iv seen, i need a goal to acheive
SO im going to draw a model on the bench and build it hence this thread, as i lost my gasses this morning im struggling to see what im doing
Might help my building
Wish you had a spell checker on here it would help me no end
something quick and simple, a bit like my funfly i designed.
cant wait to see what you come up with.
A shortened version this time
Cut the ribs and started the build, as the wing leading edge and trailing edge both narrow at the wing tip as does the wing thickness i put tabs on the rib and am building it off the board
6mm ply braceing each side of the spare
Started the sheeting but ran out of 1/16th sheet , will try to find some tomorrow
Laminated the fuselage sides and ply strentheners, then glued the formers straight on to the bench over the drawing a made
Cut out the tailplane and finand rudder, the tailplane is from 3/8th balsa and the fin and rudder i laminated two sheets of 3/16th together, i want to shape them all into an airfole section, and taper them to the tips
- Thank you received: 14473
Christ knows what the model will look like
I had a good days modelling today, outside in the sunshine nice and warm not a breath of wind, in my shorts and sandles. no shirt on
Dipped some balsa in the pool last night and curved it to fit the turtle deck at the rear
Then fit it
Glued some foam for the cowl as i want to make my own in glass, if i can, and the hatch which i will cover with balsa
wonderful looking model and so well built.
