Christmas Build 2013
- Thank you received: 14473
bit of a further delay ,next job was fitting ailerons servos.By leaving them in there previous model you dont need to go looking for anything its all there.1 st one went in easily.Some shaving of the servo bearer edges required for the servo yo fit but not a lot.The cable slid straight through the wing also.2nd one couldnt get the cable to go through but did get one through the wrong way and a connection of the 2 and the 2nd servo cable was through.But, as I started to shave a bit off the servo bearer it disappeared into the wing.Retrieved it and its now gluing back into place.
Toy Story 3 was good
[IMG]http:/ i1202.photobucket.com/albums/bb379/Stephenshaopingtang1944/014_zps12c84b98.jpg[/img]
- Sarah-Jane Smith
- Gone
- Thank you received: 2182
The Beard wrote: After the glue on the bearer set I continued gently shaving and then the other servo bearer fell off.I glued that one back in place.I was then able to shave a little more and fit the second aileron servo into position and fitted the rudder.I decided to rest for the evening
What ya resting for!!! Get on with it man!!
