Grumpy Tigercat
- Phil Wood
Remember to drill or cut any holes you need for servo wires through the ribs before you sheet everything.Si_B wrote: Might get some sheeting done later.
Simon
Assuming of course that you're putting servo's in the wings?
- Si_B
- Thank you received: 680
come back and get stuck into the build.
Have a great time Simon.
- Si_B
Got a bit of time today so finished lower sheeting on one wing, including the cap strips. Tubes in for the servos.
Going to crack on with the sheeting on the other wing, but using aliphatic so progress is slow. Then time to start mounting the nacelles.
Not sure if I'm going to glue these in or wait till I've got the wing mounted first to check the fire walls are aligned before committing to the epoxy.
Cheers,
Simon
- Si_B
- Si_B
- Thank you received: 10842
Looking good Simon
i do like good looking twins.
- Si_B
Seemed to go well, lots of balsa carvings everywhere. Will post some pics tomorrow if I get them glued on.
Simon
- Si_B
going to be a great looking model when it is done.
- Si_B
Was hoping to get this finished over my summer break but I've been a bit lazy with a lot of things. Back at school tomorrow, so the stress will kick back in..........not sure how much time I will have on my models.
Got a few things which don't line up or match even though it's correct to the plan so need to spend a bit of time sanding and tweaking before I commit to fitting the wing. Once that is done I hope it will come together.
Simon
- Si_B
like it.
