22 Apr 2016 23:37 - 22 Apr 2016 23:53 #1 by THE BLACKBIRD
Trying to build another Buck this time to the plans I have for the 50% one, this will be 1/3 scale
But not with the stainless steel tube construction, as I priced it up and gulped, things may change as I go along as I am still interested in it
The plans follow the original full size construction I am led to believe
So a dive under the workbench to see what materials are to hand
Found some 3mm ply so I made a start
Last edit: 22 Apr 2016 23:53 by THE BLACKBIRD.
Thanks: Phil Wood, Klipkopwildlife
23 Apr 2016 00:02 #2 by one tenor
Replied by one tenor on topic A new scratch built Bucker Jungmeister 1/3 scale
What is the board made from? Fibre board ? Good stuff if it is . Good luck with the build.
23 Apr 2016 19:23 #3 by THE BLACKBIRD
Just plaster board OT but did not make a neat edge on it :S
Found some 6mm hard balsa sheet and stripped it into 6mm square for the fuse sides, built the sides over the plan
Then assembled the fuselage free hand as there is no plan view on the plans, in fact im finding a lot of things missing from the plans :( just have to make it up as I go
Not doing much modelling as I still don't feel well
Thanks: Phil Wood, Klipkopwildlife, Quorneng
24 Apr 2016 19:24 #4 by THE BLACKBIRD
Got the basic fuselage structure done, just got think of a way to tie it to the fire wall, think I might get some S steel tube and create a structure within the wood frame work, I will then tie the fire wall, lower wing centre section and the struts for the top wing and the undercarriage all together :ohmy: i think
Went into the hanger tonight to do some modelling :) that's the first time since I built it :( , cut some ribs out of ply and balsa
25 Apr 2016 05:01 #5 by one tenor
Is that just one rib ?Seems enormously thick .
25 Apr 2016 09:26 #6 by Klipkopwildlife
I think there's lots of ribs clamped between the outers, certainly that's the way I do it.
25 Apr 2016 10:06 #7 by THE BLACKBIRD
:lol: :lol: :lol:
30 Apr 2016 13:13 #8 by THE BLACKBIRD
Had to cut some 6mm x 8mm spruce spars from some bigger material, so I made a saw bench to do it
Also had to rebate them to take 3mm ply
Surprising the amount of sawdust from that small job
30 Apr 2016 14:35 #9 by Quorneng
Just an observation but whilst spruce spars with a 3 mm ply web is traditional it does seem a bit at odds to the 1/4" sq balsa used in the construction of the fuselage.
30 Apr 2016 21:38 #10 by boz
looking very nice, following with lots of interest
01 May 2016 22:30 #11 by THE BLACKBIRD
The two spars made up for the first wing panel
A complex arraignment for the hinges and horns of the ailerons
Some ribs and carbon parts cut
And a dry assembly
01 May 2016 22:33 #12 by THE BLACKBIRD
And a dry fit
Thanks: Klipkopwildlife, blue123
01 May 2016 22:39 #13 by Quorneng
A classic "Frise" aileron. Provides a degree of "aerodynamic" differential and reduces the control loads as well..
02 May 2016 14:32 #14 by THE BLACKBIRD
As per the real one Simon, he builds his planes as near to the original as possible
02 May 2016 16:44 #15 by THE BLACKBIRD
Got a lot of the first wing panel built
Nice to be able to lay the whole wing plan on the bench
In fact I can get all 4 panels on there with room for more
Thanks: Phil Wood, Klipkopwildlife, Quorneng, blue123, Fly-Navy, Ralpharr2001, Septic
Time to create page: 1.363 seconds
