- Thank you received: 10844
But not with the stainless steel tube construction, as I priced it up and gulped, things may change as I go along as I am still interested in it
The plans follow the original full size construction I am led to believe
So a dive under the workbench to see what materials are to hand
Found some 3mm ply so I made a start
Found some 6mm hard balsa sheet and stripped it into 6mm square for the fuse sides, built the sides over the plan
Then assembled the fuselage free hand as there is no plan view on the plans, in fact im finding a lot of things missing from the plans
Not doing much modelling as I still don't feel well
Went into the hanger tonight to do some modelling
- boz
- Thank you received: 1420
