Plane Print Seagull
31 Oct 2022 11:19 #46 by Klipkopwildlife
Replied by Klipkopwildlife on topic Plane Print Seagull
Simon, do you have any idea what the solvent is in UHU-Por?
31 Oct 2022 12:35 - 31 Oct 2022 12:38 #47 by Quorneng
Replied by Quorneng on topic Plane Print Seagull
The UHU POR web site suggests petrol can be used to remove smeared POR stains and to clean brushes. This assumes the surface concerned resists petrol!
To be honest I have never tried it. I have found on a smooth hard plastic surface POR can be simply rubbed off the surface with your finger, at least within the first few days.
POR does eventually (years) degrade in sunlight and goes yellow.
Last edit: 31 Oct 2022 12:38 by Quorneng.
21 Nov 2022 17:25 #48 by Klipkopwildlife
I've managed to put a few parts together
Not easy to see against the light, and
The elevons are using TPU filament, you can see how floppy they are, they're hanging under their own weight. The off-white parts are LW_PLA, all the rest is PLA single wall print.
I hope to have a weigh-in tomorrow.
21 Nov 2022 17:51 #49 by Quorneng
Klippy
That looks very impressive to say the least!
I am a bit envious.
I still think it looks like a lot of plane for a 40 mm EDF, no matter how powerful it may be!
21 Nov 2022 18:29 #50 by jon.in.swansea
Replied by jon.in.swansea on topic Plane Print Seagull
I 2nd the motion about that being impressive. What is the wingspan of the beastie?
You must have managed a couple of longer electricity-on periods to manage to print some of those bits....
And goodness those are seriously large ailerons - what kind of servo can shift that much surface area?
21 Nov 2022 21:37 #51 by Eric
Replied by Eric on topic Plane Print Seagull
Ailerons - a big surface moving a small amount is just as effective as a small surface moving a long way - and is less liable to turbulate and stall!
Mechanically - inside hole on the servo arm, and outside hole on the contol horn gives most leverage - but less movement for a given servo movement.
22 Nov 2022 13:50 #52 by Quorneng
Remember on the Plane Print Seagull they are 'elevons'. There is no elevator. Those surfaces have to be large to provide any degree of pitch control with the surface so close to the line of the CofG. It is in effect a flying wing design.
My own view is they might have done better to have used inboard elevators and outboard ailerons but the configuration they use certainly flies - so what do I know. ;)
23 Nov 2022 07:49 #53 by Klipkopwildlife
Jon said "What is the wingspan of the beastie?
And goodness those are seriously large ailerons - what kind of servo can shift that much surface area?"
Wingspan is 1,500mm
I had all the parts printed prior to starting my upgrade which has taken far longer than anticipated.
They are 4.1gm servos, EMAX, ES 905, 800gms/cm, Digital with plastic gearing.
You only need high torque with speed and high rates of deflection. My guestimate is that 2.5gm would have been sufficient.
24 Nov 2022 06:54 #54 by Klipkopwildlife
I managed to weigh the airframe yesterday, 297gm. What is worrying is there's a weight differential between the wing halves, 80gm and 85gm. I'm still fettling, I'll probably only get to fitting the electrics next week.
Thanks: Eric, Flytilbroke
24 Nov 2022 12:06 #55 by Quorneng
I had similar on my Depron Seagull but it only took 1.4 grams of lead pushed in at the wing tip. The tip is a long way out!
Given you were working from Plane Print's files you can be pretty sure the wings will be aerodynamically identical so a simple mass balance should be fine.
24 Nov 2022 16:31 #56 by Klipkopwildlife
I'm not surprised since many of the wing parts were during the 'suck it and see' phase.
11 Dec 2022 13:29 - 11 Dec 2022 13:30 #57 by Klipkopwildlife
Not much done lately, at the moment our load shedding is 4hrs on and 4 off!:(
I have done a bit of painting.
That's stalled, waiting for some matt grey.:(
Last edit: 11 Dec 2022 13:30 by Klipkopwildlife.
11 Dec 2022 17:48 #58 by Eric
Is that 'tail' on crooked, or is it a funny camera angle?
11 Dec 2022 23:10 #59 by Quorneng
Eric
On the Plane Print Seagull the whole tail assembly is the rudder so its angle entirely depends on a servo.
12 Dec 2022 08:52 #60 by Klipkopwildlife
Eric wrote: Is that 'tail' on crooked, or is it a funny camera angle?
Already answered by Simon, the black dot you can see in the thrust tube is the hinge point.
Going to town tomorrow so hope to get some matt grey, load shedding permitting.
Time to create page: 0.998 seconds
