Vought V173
Each is cut from 3mm Depron and reinforced with a small strip of CF "tow" on each side.
The rudder uses two tiny PLA printed pin hinges. They are 3mm wide & 15mm long. Again many attempts before I got it right!
The second fin with its hinges in place.
Fiddly to do but it seems to work.
Fitting the fins is no problem but I will refrain from doing so as I have no idea yet how to connect the rudders to the servo!
Whatever is used has to clear the rear elevator when it is in the "up" position.
A short "control test" video with everything powered by a Lemon "stab" receiver set to "Delta" configuration
https://<iframe width="560" height="315" src="" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" referrerpolicy="strict-origin-when-cross-origin" allowfullscreen>
As expected the elevator and ailerons are set to 50%, the rudder to 70% to keep the movements within reason.
Not shown in the video but even the stab inputs work in the correct sense - I think.
Getting close to fitting the motors and ESCs then it can be tissue covered.
You may well be right but the surfaces are operating at short moments compared to a normal plane and the inertia will be large with the relatively heavy motors and props effectively not only right at the wing tips but a long way forward of the CG.
My guess is for the first hops I will be relying heavily on the abilities of the gyro.
Keeping to scale I decided to mimic the engine cooling inlets to cool the ESC which are mounted behind the leading edge in about the same place as each flat 4 was.
The ESC is mounted "on edge" to the airflow.
It follows that when the wing is fully covered the air has to get out so a scale cooling opening.
The other advance is the Lemon Stab Rx is now fitted and the servo leads shortened accordingly. Soldering connections in 32 AWG servo wire is fiddly!
Now I have just got to do the same thing to the LH motor and ESC - as well complete the repairs to the Swiss Venom.
Twin ESC and the necessary wiring.
Twin intakes for ESC cooling and those huge props.
Next will be the ridiculous stalky undercarriage followed by the cockpit which will be a lightweight "built on" structure.
Only then can the tissue go on.
Not done any tissue for some time!
With weight in mind I wondered if it would be possible to print wheels in LW-PLA.
I tried two sizes.
Obviously they are not that wear resistant but I very much doubt the V173 will ever do much ground running.
They are indeed light. The smaller ones just over 1.2" diam weigh 1.1g each. The bigger 1.5" diam weigh 1.8g.
Actually massively strong. A single wall and a 15% gyroid infill that looks like this when printing.
The 1.5" ones each take 25 minutes to print.
- jon.in.swansea
- Thank you received: 1192
Build a cradle and treat it as a VTOL.... util you figure out it's characteristics
- Thank you received: 14473
uk.search.yahoo.com/yhs/search?hspart=tr...61423&p=depron+sheet
I then looked through my paint draw to see if I had any bright yellow.
I didn't but there at the bottom was a full bottle of EzeDope!
So I will soon have 2 full bottles and its not as if I do much tissue covering. The icing on the cake is the V173 used up the last of my Model Span tissue.
First I want to move the tail plane servos out to the body extremity to shorten the lcurrent long carbon torque rod.
Like this:-
The tail planes will still operate as elevons.
At the same time the rear elevator surface will be fixed. All the inflight pictures show the full size elevator in the neutral position. It appears it was not used except for the landing flare to allow for the very nose high attitude.
Well that's the plan - at the moment!
