3D printers
26 Mar 2018 19:31 #1 by Klipkopwildlife
3D printers was created by Klipkopwildlife
I've been looking at buying a 3D printer, after 3 days my head is spinning and I still don't know which way to go!
I'm sure alloy frame is the best way to go, but then what's the best axis configuration?
Then there's Controller software, Cura, Repetier-Host, Printrun, and I'm sure there are others, can you change between them?
I'm at the stage where I've asked Simon and Tony and I'm still no further ahead. I'm looking to spend about 250quid, any ideas anyone?
26 Mar 2018 20:51 #2 by Ex-Member
Replied by Ex-Member on topic 3D printers
i would go for the Anet like simon has.
with a few mods it works very well for a hobbyist.
28 Mar 2018 11:17 #3 by Klipkopwildlife
Replied by Klipkopwildlife on topic 3D printers
I do wish you hadn't said that Tony! [badass] I was going to ask if this would be OK.
I like the cube design which means you cancel the 'out of vertical forces' and 2 Z motors means that you don't have to carry the Z drive across the frame with a toothed belt.
The problem I see with the inverted T design is the tower can lean against the acceleration of the print head when you're printing very tall objects.
There may be other drawbacks to either design, comments please, even if you think it's a stupid comment.
28 Mar 2018 12:34 #4 by Ex-Member
the reviews for it are not great Tony.
but as with most things, you pays your money and takes your chances.
I'd sell you my old Anet A8 if i could figure out how to take it apart again and then get it to SA.
28 Mar 2018 15:11 #5 by Quorneng
Replied by Quorneng on topic 3D printers
Klippy
I can understand the structural advantage of the cube design but you do have to wonder why it is being sold at such a discount. ;)
I am not sure the design uses any less belts than say the Anet but it does have all its the cables contained with cable chains
- which I have added to my Anet :) .
I do have a concern that all the printing takes place right at the top of the cube (note the head generate significant loads as it is accelerated) so there is the potential of some 'flexing' (loss of accuracy) as the cube itself has no diagonal bracing.
The electrical supply requirement looks a bit alarming. 220/100 V (fine) but 30A! That I very much doubt! :woohoo:
30 Mar 2018 11:32 #6 by Klipkopwildlife
Well I bought an online copy of '3D printing for dummies'. Am I any the wiser, no, but I've put everything together with what Simon and Tony have had to say and it came down to a choice between this or or this
I went for the first one in the end, I felt the E2 looked a bit flimsy even though it's an alloy frame.
Thanks for looking and helping.
30 Mar 2018 12:32 #7 by Ex-Member
The A6 looks to be a good printer and has come down a lot in price since i last looked.
now the fun starts. ;)
30 Mar 2018 15:00 - 30 Mar 2018 15:01 #8 by boz
Replied by boz on topic 3D printers
Although I know nothing about 3d printers, I would say the one chosen will in my opinion pay for its self in a very short time, it looks quite a lot of printer for a very good price.
I'm sure you will have plenty of things to make .
Last edit: 30 Mar 2018 15:01 by boz.
03 Apr 2018 19:33 #9 by miniconverter
Replied by miniconverter on topic 3D printers
Was going to say take a look at the Wanhao D4S works straight from the box heated bed dual extruders then saw the current price and they have gone up a huge amount only paid £400 for mine a couple of years ago
Thanks: Klipkopwildlife, boz
04 Apr 2018 08:50 #10 by Klipkopwildlife
Thanks for that, all comments gratefully received. Being an inveterate 'tinkerer' I wanted something that needed to be built up so that I could also see how it works. The half lifetime I spent fixing and programming CNC machines will also come in useful. If you look at my profile you'll see I live in the bush and importing large objects becomes a very costly exercise. As it was the Anet cost me 156Gbp, carriage another 65 and Customs will probably rush another 50 or so. I'm ever minded that the up front cost can easily double.
Thanks: THE BLACKBIRD, boz
06 Apr 2018 14:18 #11 by bond007mas
Replied by bond007mas on topic 3D printers
[badass]
MY 3D PRINTER HAS PAID FOR ITSELF (£400) ON THE SR-71 ALONE
2 X ENGINE CONES
2 X REAR ENGINE CYLINDERS (INNER)
2 X REAR ENGINE CYLINDERS (OUTER)
14 X AFTER BURNER SHAPES
28 X CORRUGATED WING INSERTS
1 X LARGE NOSE CONE
2 X NOSE WHEEL DOORS
1 X UNDER BODY TURBINE COVER AND GRILL
30 X NACELLE INTAKES
PILOT
ALL THE SERVO HORNS
AND MANY MORE
SO REALLY IT`S A WIN WIN SITUATION
Thanks: Klipkopwildlife, Ex-Member, THE BLACKBIRD, boz
06 Apr 2018 18:18 #12 by Klipkopwildlife
Thankyou James! I have no doubt my printer will give me many hours of fun. My next problem is to learn a 3D Cad program.
06 Apr 2018 20:12 #13 by Ex-Member
most people use fusion 360.
10 Apr 2018 13:17 #14 by Klipkopwildlife
At $25/mth I can't afford Fusion, as a retired hobbyist I'm quite prepared to pay a once off, to show willing. When I wanted to use Mach3 for my CNC Router/Laser engraver I could use it free as long I didn't exceed 500 lines/program. A small once off , which I paid, allowed me to have as many lines as my memory would allow
10 Apr 2018 15:04 #15 by Ex-Member
i uae "blender" as it is free, but some peple find it hard to master.
there are lots of "how too" vidos on you tube.
Time to create page: 0.750 seconds
