Anet A6 3D printer
I just can't get it right, I can only get about a 10% reduction in weight. When I try and print anything the feed stops part way through.
I'm at my wits end.
I can't believe I managed to print an entire plane. I'm about to try and use some of my precious Esun LW-PLA, of which I have very little, to see if the problem might be the material.
Load shedding and home commitments don't help of course. I was about to return everything to the specification that I used for the Seagull (a large job) when I I thought, bugger it, let me put the Esun LW-PLA in that I used for the Seagull (still to be maidened)
Eureka! Having been convinced that the was nothing wrong with the new filament the tried and trusted works fine. Thanks for the input Simon, I pre-empted you by about 3 hours.
We'll see if that works.
- jon.in.swansea
- Thank you received: 1192
Cold with no drafts here in the winter - sometimes I needed to take a hair dryer to the Prusa Mini because it refused to start when the room was <15C.
I noticed that Cura had an update, 5.4 so I've switched to it.
Lots of stringing but usable.
At the top is the component printed with Cura 5.4, a dramatic improvement.
As a point of interest, there are 2 red (+) feeders and 2 black (-) feeders to carry the 10 amp current. In the bed itself there are 2 heating elements with no internal connection between them. One heats the outer section of the bed and the other the inner. Obviously while the fault was intermittent the outer section wasn't warming, accounting for the loss of sticktion.
Some work with a soldering iron and it's now hard wired.
- Thank you received: 14470
Or did you mean the - presumably clamp - joiner was overheating?
The female part of the plug is not fit for purpose, there's nothing wrong with the wires.
The view from the top.
from left to right, 2 positives , thermister wires, 2 negatives
Here you can see the resistive connection has caused localised overheating.
What does the pin that goes in to it look like? Any sign of heat?
Once that type of connection get that hot it is possible the pin is no longer a good 'slide' fit into the socket.
It looks like either the springy bit on the pin has gone, or the socket has spread slightly, and has been arcing.
- jon.in.swansea
