Light Weight PLA, (LW-PLA) is a newish filament that has a foaming agent in it. The foaming occurs when extruded at higher temperatures (typically 250 - 260oC). Since my sister was in the UK recently I got her to bring a roll back with her. The colour selected was natural since then I wouldn't have to add much weight in the way of paint.
These instructions on how to use came from the Colorfab web site.
1 PRINT CUBES (Download here: Test Cube) AT A SET SPEED IN TEMPERATURES VARYING FROM 200°C UP TO 280°C
2 MEASURE PERIMETER THICKNESS OF EACH CUBE, NOTE TEMPERATURE WITH HIGHEST EXPANSION.
3 PRINT CUBES WITH DECREASING STEPS OF FLOW, USING TEMPERATURE FOUND IN STEP 2.
4 FIND THE CUBE AT WHICH PERIMETER THICKNESS EQUALS NOZZLE SIZE.
My first problem was the test cube wouldn't download, it's item 271736 on Thingyverse, once I had the cube, how hard could it be?
If your printer has a PTFE feed tube to the nozzle (most do) then even 250C is close to its limit for protracted use.
It is this fact that is holding me back more than the cost of the LW-PLA
I have installed a Titan Hot end, these are the parts
if the tube is PTFE (probably) it's never given any trouble.
Considerable steps are taken to keep the heat away from the tube
There's a 40mm fan on the other side of those fins
The feeder tube comes in at the top of the carriage
and goes up to the extruder stepper that's mounted remotely to keep the weight off the carriage.
You can see the discolouration as the temperature goes up, the expansion was the same at 250oC and 260oC so I decided the temperature to use was 250oC
The wall at 200oC was 1.16mm, and at 250oC was 1.51mm
Having tried, and failed to get the wall thickness down to 0.4mm, note the poor infill of the 30% flow rate floor.
I then realised that I was mis-reading the instructions, I should be reducing the flow rate until the wall thickness was the same as the 200oC wall
63% was the number!
What was interesting to me was the weight, the 200oC cube weighed in at 25grains, the 250oC cube with the 1.16mm wall was 15.2grains
As you can see that didn't go well!
Going back to the Plane print web site I noticed they quoted a setting I didn't seem to have. What I didn't know up to then was that your profile panel can show different settings according to whether you selected Basic, Advanced, Expert or All.
I didn't realise Cura was so powerful. Some 180 different settings have to be fine tuned according to a closely printed crib sheet! After I'd input all the setting changes using the 'All' profile the very next print gave me this
The first, closest to the camera, fell over 10minutes short of a 6hour print! I changed the base to Brim and the second attempt, perfect.
Having achieved a pretty significant weight saving of 25 to 15 I suppose the next is to try to quantify their relative strength and stiffness.
After all the important advance is to save weight but with less than a corresponding reduction is strength and stiffness.
Is the finished foamed surface significantly different to that of a non foam filament?
Once the LW-PLA has foamed it doesn't extrude easily. With PLA you can print a component, take it off the Bed, and start printing another component, try this with LW and you're in trouble.
This chamfer is one of the problems.
- jon.in.swansea
- Thank you received: 1192
The finished item is very flexible but very strong in certain directions
this incomplete skin is quite flexible
then I can squeeze the fins together
by comparison the rudder hinging point (the whole thing moves for control)
is very strong and in-compressible.
This is a surface finish comparison
The layer height is 0.25mm but the cube is 0.15mm so not really comparing apples with apples.
On the left at 250oC, the foil surface is 0.75 and weighing 52.1grains.
On the right at 240oC, the foil surface is 0.85 and weighing 53.4grains.
13% thicker (stronger?) but only 2.5% heavier, I think I'll be printing at 240o.
Our current load shedding means I only have 4 uninterrupted hours of print time, the prints waiting to be done are all in excess of 8 hours. These parts, a cover and the thrust tube have to be done in PLA
The thrust tube is 40mm in diameter and 0.5mm thick weighing 68gns, I was quite impressed with it.
If you have a power cut
You get this, without the cooling fan the filament heated in the feeder tube, and expanded in the tube, original filament at the top, hot end at the bottom. This took several hours to get out!
Once the filament has foamed it will not extrude so you must include an extruder filament retract in the post processing, I use 100mm. The retract gives you a spoiled end
You must pull out the filament and cut this off.
Failure to do this will result in zero extrusion with the next print. Obviously as the next print starts you must remember to advance the filament 100mm if you are using anything other that LW-PLA.
This all very useful stuff. Many thanks.
It would seem you have more problem than most of us, power cuts and 3D printing do not mix!
I would imagine such a situation is even worse when using LW-PLA!
All tall objects need a Brim, otherwise they fall over!
Failure to set the Flow rate (63% for me)
On the right is 100%, left is 63% The internal fill is visible but can't be felt. What is of concern is the obvious movement towards the end of the 180mm print
At this stage I do have a number of parts that are usable.
Top right is a wing tip, sands quite easily but does get grubby. The outer ailerons look ok but the inners, 2 required, definitely need a re-think.
After the deformation the part returned to the original shape.
Then I tried the thumb test
I'm putting about 10lbs/inch2
Anything that I printed at 260oC is definitely not fit for purpose, the part crushes or breaks quite easily.
