JB Atoms
Thanks Doug, Mr Burford is a man after my own heart and has me drooling over some (all?) of the machines he has!Doug wrote: I believe Mills engines used hardened pistons and cylinder, and because of this were virtually impossible to wear out. A modern example of this set up is the very high quality Peter Burford 0.3cc engine. This explanation on his web site states that a small variation in hardness is enough to prevent galling. See www.peterburford.com.au/construction/
Doug
Certainly the Indian Mills have not been hardened anywhere!
Boz, General engineering practice is that Ball races can be hard outer, hard balls and hard inner because there is no slippage between surfaces. (Paradoxically using too good a grease (Molybdenum disulphide for example) encourages slide, leading to the rapid demise of the race)
Where you have two surfaces with differing speeds it is normal in the motor industry to fit a dissimilar material as a carrier, bronze or white metal are examples. The thinking is that the softer material picks up any impurities in the oil, these impurities (grit etc) could cause galling elsewhere in the machine.
As Mr Burford says, a difference of 7 Rockwell hardness's is enough to stop galling (pick up) and I still don't like the idea of running steel on steel!
Steel piston rings with steel liners. Just sliding and pretty common.
The piston ring/cylinder example is cheating a bit, the ring is very hard (try expanding one too far some time) and the cylinder is very soft (relatively speaking) otherwise you would never be able to re-bore. Mr Burfords' 7 points of Rockwell would appear to hold true. The problem with testing for Rockwell hardness is that the test damages the part, and I don't have the facilities.
To continue
This is the EN30B ready to turn, why is it coloured you ask? All types of steel have an international colour code, normally painted on the end of the bar stock. Once the bar stock end has been cut off it becomes the Storemans job to paint the code down the entire length of bar!
Most damage in factories is caused by incorrect steels being fed into the system!
Here I've doubled the feed rate in an attempt to get the chip to break. This is a cheap Chinese machine, the spindle speed has dropped and the chip is no longer curling, answer, more horse power, I don't have any.
The material turned down the the outside diameter of the crank web, our first objective.
Then down to shaft size, plus a bit.
I've left about .2mm (8thou), I hope this will be enough for lapping.
I will then thread the end 2BA while I still have the advantage of the thicker shaft.
I always make a drawing for posterity, my Engineering master at school would have had a fit! But at least I know what it looks like!
The manufacturers intended to have all surfaces glass hard to reduce friction and enhance life, personally I don't think they've gone the right way about it, and certainly the reviewer in the article was not overly impressed. He battled to get one engine to run consistently and the other took a long time to approach consistency and higher revs. It got so hot he had to pour raw fuel over the crankcase to cool it down!
A brief word about terminology, hard is not necessarily strong, tough is not necessarily hard. Hard and tough together is good, today we can surface harden a tough material using a coil driven at high frequency. When we pass a shaft through the coil the surface heats up and we then quench immediately using a ring of fluid jets. This gives us the best of both worlds, a glass hard outer with a tough inner as support. We can even control the degree and depth of hardness by adjusting frequency, current, speed of pass, and type of fluid used for quenching.
If we want to get really fancy we now have steels that must be heated in an oven containing an inert (specific) gas and held within 5o of a specific temperature for a specific length of time Using todays methods we could make model engines that will literally last for ever, running on a breath of oil, or no oil in the case of a petrol engine. The only problem would be, we couldn't afford them!
With care it is possible to case harden just the bearing surfaces of a crankshaft leaving the rest in its tough/strong condition.
I believe this is what was done on the original Mills 75 where the threaded nose of the hard crankshaft would bend and could safely be straightened again.
Mine did and has been!
To continue, threading after first checking the thread is correct.
finish lapped with the driver taper machined.
and ready to part off, not a job I enjoy, it needs a really rigid machine because the tip is so wide at 3mm
And with the shaft blank in place.
And make sure it's running true.
- Thank you received: 10844
BTW you said something about the power of your lathe not up to some work, a bit ago.Apart from fitting a more powerful motor you could try a new belt. As belts wear there comes a time when even as tight as you can get them they slip because the vee has worn down and the only friction area is the tip of the Vee. A new belt can sometimes work wonders. One of the toothed ones may help. If granny has already sucked this egg I apologise . I remember one C/H pump I was looking at in a presbytery .The priest in charge was saying how the noise from it kept them all awake. I slackened the belt and spun the motor and pump and there was no sound from either . I then gave the belt a twist and revealed loads of cracks. In fact it was all cracks. I found a suitable car belt .Fitted it and Silence. The difference was astounding. The priest was very grateful as their plumber said they needed both replaced.Robbing bleeder..Anyway it might be worth a try. [badass]
