JB Atoms
My next plan is to assemble the engine that was sent as a sample and see if I can start it.
John O/T
Timing, controlled by the hole in the crankshaft, same as the sample, check!
Plenty of suck when I put my finger over the venturi and flick, check!
Compression, plenty, if I wind down the screw I can stop it from firing, check!
Leakage from the back plate or cylinder liner, nothing, check!
Propeller, either 8 or 9inch, runs fine on my Mills 1.3, check!
I'm beginning to think the problem is fuel related, 40o and 3,000ft, if I take the lid off my Ether bottle I can see the Ether boiling. My next intention is to assemble the complete engine and attempt to start it, if it starts then I can start swopping exterior parts across.
- Thank you received: 14470
Gets very hot and any attempt to refuel within 10mins just results in the fuel boiling out of the tank. It runs for about 60secs on a full tank driving a 9x4 propeller. I can't get it to start by hand, but then I never was very good at starting, just a single touch with the starter and she's away.
Now I've got a runner I'm going return to the other engine.
I make a fresh batch of fuel each time I'm going to try something. 60mls at a time, when I've finished I pour the contents of the plastic refueling bottle back into a 100ml glass bottle.
My new CS Mill 1.3 runs on this mix as a cross check, but also won't start by hand, but then I'm sure that's me!
Can't start a Mills 1.3 by hand?
I would have thought that was almost impossible.
I have started mine by hand and holding it in my hand! :woohoo:
- Mike Rolls
- Thank you received: 573
P.S. does anyone ;know thread sizes of AMCO .87 Crankshaft and comp screw .Also what type of solder was used to attach transfer passage and intake tube to the cylinder.At some time in the future I would like to borrow a spinner to copy if any one can spare one for a short time. As I say in the future.
In my current situation I am convinced that 9/10 of my problem is fuel, I can't import any and it's not made locally, diesels were never popular here. The one item that all fuel manufacturers seem to add is Isopropyl Nitrate, which seems to be another name for Amyl Nitrate (please comment anyone) This additive I know improves starting characteristics.
Paradoxically Amyl Nitrate is commonly used in the sex industry but there's no sex shop in Lephalale!
- boz
- Thank you received: 1420
- Mike Rolls
Isopropyl Nitrate C3H7NO3
Amyl Nitrate C5H11NO3
Note the additional hydrogen atoms in AN. I think the sex shop usage is probably amyl nitrite, not amyl nitrate. Nitrite is a constituent of one of the ‘recreational’ drugs known a poppers (or so Wiki tells me!)
- Mike Rolls
I am sure the lack of a fuel dope is the cause of your hand starting problems.
From what I remember Amy Nitrate was the 'magic' ingredient in Mercury No 8 and it ran all my diesels superbly!
