HobbyKing NEMESIS. Poly's bought an electric ARTF.
- Phil Wood
That's exactly what I had in mind Garry .... Here's a pic of the U/C mounting holes .... the sheet of ply has captive nuts fitted and is only about one & a quarter inches wide.Garry Pollard wrote: This is always a fault on ARTF Pol. I always beef this are up with hard wood triangular stock to really beef it up
If the U/C were to get a rearwards knock. such as hitting a stone or tuft of grass, it would try to rip the leading edge of the ply cross member out of the recess.
What is needed is triangular section to attach this cross member to the Fuz sides a lot more securely.
It may be a bit fiddly to get at, but I may even see if I can get a coat of GRP on the cross member itself.
This would have to be done from the inside & it's almost impossible to get at because the base of the battery hatch is in the way. (See pictures) .... It's not even practical to remove a piece of covering & glass it from underneath .... it would mean recovering the whole underside of the fuz.
- Phil Wood
- Phil Wood
I think they must use some form of hot glue, can anyone clarify this?
Look carefully at these pictures and you may just be able to make out some blue GUNK .... many of the joins show no signs of this so I'm taking no chances with this one.
I'm going to get a syringe with a long extension & trickle PVA wood glue along every seam .... it may add a few grams but a 5-6lb model won't notice it.
- Phil Wood
- Thank you received: 14473
- Phil Wood
It looks like aluminium Eric .... but feels very heavy, more like steel! :woohoo:Eric wrote: If the wing joiner is a carbon bar, do NOT tighten the locking screws! That will crush the bar, and next time you pull a bootful of G,- - SNAP! You'd be better with a pair of cuphooks and an elastic band.
- Sarah-Jane Smith
- Gone
- Thank you received: 2182
- Dean M
- Thank you received: 326
I nearly choked on my latte.
Can I suggest you thin the pva with some distilled water, it'll 'wick' in better.Polyphilla wrote: The next complaint we often hear about ARTF models is the lack of glue used in assembly.
- Phil Wood
Oi gobby, are you going to come & have a blast at flying this beastie?willowlea wrote: looks good! Have you finished yet? have you, have you?
go on Sarah, it would be a great meet up!!!! [badass]
