HobbyKing NEMESIS. Poly's bought an electric ARTF.
04 Feb 2013 23:45 #31 by old fart
Or alternatively you could use Superphatic adhesive, it is made to wick into joints. :)
05 Feb 2013 01:57 #32 by Eric
Haven't heard of that one!
05 Feb 2013 02:15 - 05 Feb 2013 02:18 #33 by old fart
Last edit: 05 Feb 2013 02:18 by old fart.
Thanks: Eric, THE BLACKBIRD, Sarah-Jane Smith
05 Feb 2013 05:36 #34 by Sarah-Jane Smith
Replied by Sarah-Jane Smith on topic HobbyKing NEMESIS. Poly's bought an electric ARTF.
Polyphilla wrote:
willowlea wrote: looks good! Have you finished yet? have you, have you? :P
Oi gobby, are you going to come & have a blast at flying this beastie?
go on Sarah, it would be a great meet up!!!! [badass]
got 3 weeks off in one week so may take you up on that haha! tho not the flying this plane bit, would be mortified if I crashed it!!!
It looks lovely Phil, more piccies please!
05 Feb 2013 06:23 #35 by Phil Wood
Piccies will follow, I've just had a day off today. .... I'm serious if you want to fly it .... if you crash it then so be it. I don't want to sit & look at a pretty model, it's a tool or a toy & it has to be played with whatever the consequences .... I'm still waiting for you to say when you want to try slope soaring at the Orme ... I've got the models ready & waiting.
05 Feb 2013 06:26 #36 by Sarah-Jane Smith
You buddy box me if I bring my TX?
05 Feb 2013 06:31 #37 by Phil Wood
willowlea wrote: You buddy box me if I bring my TX?
If that's what you want, ... you'll be off on your own after a few minutes & we can then get stuck into some combat .... you cannot damage these models, you can crash them into the cliff face. [badass]
05 Feb 2013 06:35 #38 by Sarah-Jane Smith
wooooooooooot! get cracking and build it then would love to see you maiden it and would love a go at combat!!! am off for 3 weeks end of this week so will sort something out, cheers Phil :) :) :)
Do those cliffs do that pesky jump up and hit plane milarky that Simon's trees do? :whistle:
BUILD!! got me excited now haha! (clean that mind! :evil: )
05 Feb 2013 06:42 #39 by Phil Wood
willowlea wrote: wooooooooooot! get cracking and build it then would love to see you maiden it and would love a go at combat!!! am off for 3 weeks end of this week so will sort something out, cheers Phil :) :) :)
I don't need to build the combat models, I already have them & they are ready to go at a minutes notice.
I can use them on 2.4gHz with a buddy lead if you have a Specky Tx or we could use 35MHz & I have two JR Tx's .... it's all ready, all you have to bring is yourself.
Pol
05 Feb 2013 08:40 #40 by Phil Wood
The Beard wrote: Yes Pol the u/c came off with not much of a landing.Mine didnt like slowing down so the landing speed tended to be at the point where the model would bounce back up.The problem was it tended to bounce into a roll and cartwheel
You're putting the wind up me by going on about the landing speed of this thing.... It's a 60 inch span model weighing 5 -6 lbs..... why should it be any faster on the glide than any other similar model?
For those who don't know, I phoned Stephen for his opinion on this model before I ordered it. I remembered that he'd had one.
Pol
05 Feb 2013 20:21 #41 by Eric
I suspect what he was saying is - it won't slow down!
Racers are pretty slippery beasts, and unless you can get in a long low approach, you may have trouble with the lack of airbrakes.
06 Feb 2013 15:13 #42 by Phil Wood
Right, got a little problem with motor selection ..... the manufacturers suggest a 3548 850KV motor.
I've got a 3548 1100Kv motor which would probably be fine... but the mountings are wrong.
This thing seems to want to mount from behind the firewall ... Eric has suggested that I may be able to reverse the shaft, & this would seem to be the logical choice.
I've also got a 980 Watt 800KV motor which I think would make the thing have multiple orgasms.
Third alternative may be this & I need to order it now If it's a a good choice.
www.hobbyking.com/hobbyking/store/__1958...W_UK_Warehouse_.html
But it's still the wrong mounting!... although that is moderately easy to sort out.;
Pol
06 Feb 2013 15:47 #43 by Ex-Member
get the prop drive adapter that bolts onto the end without the shaft.
then you only have to drill a hole to take the shaft in the fire wall and mount how you want.
i use them motors in all my stuff with the prop drive adapter.
06 Feb 2013 16:06 #44 by Phil Wood
The problem is just situating the motor so that the prop just sticks out of the cowl.
I would have thought the suggested motor would have been an easy job to fit ... I'm not a bad builder & it will be easy to adapt any motor to fit ... but for review purposes this could be a problem to a beginner.
Having said all that ... they do make it clear that this model is only for advanced boffins like me. [badass]
06 Feb 2013 18:03 #45 by Phil Wood
Just had a problem shopping at HK .... I decided to go for this new motor & I also needed two sets of mounts ... 1 for the other 3548 motor that i have.
Every time I get to the check out it says my cart is empty.
I've messaged HK & told them the problem, let's see what response I get before I rip the crap out of them.
Time to create page: 0.626 seconds
