A tiny scale plane
i feel a 108" version brewing in my mind.
have to steal your plans one day. he he he
The LH wing ribs, tops spar and front skin.
Like this it is rigid enough to allow the aileron to be cut out and the LE too be fitted and sanded to shape. .
So far it weighs 1oz. (28g)
Then the RH wing has to be completed to the same standard. Should be a bit easier as all the parts are already cut out..
Originally it was dark stained - very fashionable in the 1920s?
The RH wing now has its ribs and shear webs added ready for the leading edge sheeting and the top spar flange.
The next design issue is the construction of the booms.
So far I have used glass fibre tube for such things which are almost unbreakable but on the heavy side and anyway would not be the correct profile for the Cessna.
Maybe a bit of experimenting is required..
Quorneng wrote: As I am also stripping, repairing and polishing a dressing table and wardrobe progress is slow.
Which servos will you use?
They are quite a 'tall' oval so can be made up from a hollow box with bulging sides and sanded to shape top and bottom.
The long centre 'rib' prevents the sides squashing in.
The boom overlaps the top and bottom of the spar.
The boom and wing.
The elevator servo wire will run inside the boom which will be 'interesting' to do!
The boom is so narrow at the tailplane end that even a 32AWG servo wire has to lie flat. :ohmy:
It seems rather strange to completely assemble the wings and tail before even starting the fuselage.
- Grumpy42
Thank you for thee kind sentiments - much appreciated.
Moving on a bit faster - the wing, booms and tail complete with control surfaces added.
Attachment WingTail.JPG not found
Just the wing tips to add.
There is a bit of detail finishing to do. With the servos installed it weighs 5.1oz (145g). Hopefully it will be about 17oz all up.
- Grumpy42
He, he, he I can hear the Gasser sobbing from here. :evil: :evil: :evil:
I would indeed advise small.
Foam in general and Depron in particular is not a direct substitute for wood and only at the lighter end of the spectrum does it have real advantage.
I am not sure how well Depron reacts to glow fuel although there are IC foamies that seem to manage with a sticky tape covering, claiming it just wipes clean.
Foam is cheap. The Cessna so far has not quite used 1 Depron sheet that's £2.99. The glue costs as much as that!
It is surprisingly big.
Like the late Libelle built as a planked half shell and then the other side added on to it.
I am making up some of the design features as I go along however one feature now fixed is for the complete canopy section be removable for access to the battery.
