A tiny scale plane
cant wait to see it finished and flying.
any chance of a copy of the plans as i fancy building a slightly larger version from balsa.
As it is being built as a true monocoque there is no internal structure at all just the formers and ribs to hold the skin in shape.
The extra fuselage formers not shown on the three view were created by putting the adjacent ones next to each other and 'guestimating' the outline of the intermediate one.
A NACA2412 wing section was found on the web, printed out at the right size and then hand redrawn less 3mm all round to allow for the Depron skin.
I have to admit its a balmy way to make a plane but it works for me! :woohoo:
To be honest this picture is as much for my benefit as anybody so I have a record of where it is as it will be completely buried!
The slightly unusual motor mount tube spanning the first two formers.
The actual particle board motor mount is glued inside the tube 1/2" back from the front bulkhead.
Installing the rear motor can wait as there is sufficient access until the wing goes on.
wish i could build that well with balsa.
looks like i will have to find a plan for one of these.
What really puts me off even trying this sort of thing in balsa is the expense!
In Depron the cost of the glue is greater than the material. :ohmy:
Now this is black, very black!
It will be sprayed with a clear lacquer, not so much for a gloss finish but simply to keep your fingers clean! :woohoo:
Although the rear prop is reasonably protected the front one could get damaged so I thought I better order a spare from GS - they do a matched handed pair very cheap!
It was then I discovered I had made a fundamental mistake. :woohoo:
I originally sized the O-2 for 9" props but to my embarrassment I discovered they are 8". :blush: :blush: :blush: and of course they don't do a 9" version :evil: Still it doesn't really matter as there is masses of 'push' (vertical on one motor?).
At 8" that rear prop is going to be even better protected than I thought!
- Dean M
- Thank you received: 326
Enjoying watching this come together
It is one of those build threads where I can't wait to see the end product
I nearly choked on my latte.
It has a ferocious level of thrust so I just couldn't risk full power with both running.
As this is a super lightweight model I have decided to go for solid with painted windows as the complete canopy can then be made of Depron.
Still more planking!
Very light it will be held down with magnets.
However if I don't like the effect the underlying structure does allow full glazing to be added.
The canopy removed.
It is basically a big light (1/2oz) box. Its shape means only its leading edge needs a magnet.
The next job is to work out the best way (and colour) to paint the windows on. Pale green is possible or maybe a silver/grey would be better with such a dark colour scheme.
