Auster mk5
feel free to shoot me down on this one, though only if you have any better ideas.
the front cockpit former will be 6mm ply. the one behind the front seats will be 3mm ply. both going over the top of the cockpit.
the fixed wing center section will have 2 6mm ply ribs glued to the fuselage.
the wing mounts will be like the original, being 2 u brackets on each side joined together diagonally across the top of the fuselage by piano wire.
the wings will bolt onto these and be supported by piano wire struts back to the 6mm ply floor.
the rear of the cockpit roof where it runs back to the rest of the fuselage will also be piano wire fixed to the cross brace and fixed to the ply fuselage former.
then glazed.
should look like the original method but maybe a tad over scale due to strength issues.
will it work??
help please.
The most Auster were placarded +4g to -2g.
The intermediate bracing halves the effective strut length allowing it to take compression loads.
The Aiglet was actually cleared for aerobatics but the rather low Vne meant you had to know really what you were doing.
- Dean M
- Thank you received: 326
Hopefully we will get to see this come together I could do with picking up some tips quite fancy building a 1/4 scale cub soon.
I nearly choked on my latte.
- Thank you received: 14470
not happy with the build method i was going to use.
i think i will go back to the old method of building and try to make the model a lot more like the original in construction.
been looking at balsa dowel for the fuselage structure.hmmmmmmmmmmmmmmmmmm
Are there any bits you would particularly like to see?
:lol: :lol:
By using dowel I presume you are emulating the steel tube construction of the original?.
