Auster mk5
17 Jun 2014 11:01 #316 by Monz
Replied by Monz on topic Auster mk5
And I just thew out an old black rubber skirt! Knew I shoulda kept it ;)
17 Jun 2014 11:55 #317 by THE BLACKBIRD
Replied by THE BLACKBIRD on topic Auster mk5
Hmmmmm makes one think ?? :) :) :)
17 Jun 2014 12:58 #318 by old fart
Replied by old fart on topic Auster mk5
Monz wrote: And I just thew out an old black rubber skirt! Knew I shoulda kept it ;)
Along with the mask and whip? [badass]
17 Jun 2014 20:18 #319 by Eric
Replied by Eric on topic Auster mk5
No, Tony, you can't have a slice of my scuba wetsuit! (It's a bit thick anyway, at five milli's!) :lol:
18 Jun 2014 18:10 #320 by Ex-Member
well after gardening and some house work i got to spend a couple of hours on the Auster.
doors fitted.
sliding windows in
rear seat and luggage glued in.
need to paint the window frames, fit some matting, finish the dash and then fit the last bits of structural wire.
then i can look at the u/c and cover her.
back to the wings now i suppose.
18 Jun 2014 18:21 #321 by Monz
That is lovely Tony!! Don't forget the half mil chart on the dash ;)
18 Jun 2014 19:02 #322 by Ex-Member
i was thinking an a to z of bedfordshire in one of the door pockets and a copy of the bmfa mag in the other. :P
19 Jun 2014 08:35 #323 by Ex-Member
as my funds are very tight over the next couple of months, i will only be doing little bits as i can afford to do them so the build will slow down even more.
i apologize for the delays. :(
19 Jun 2014 10:17 #324 by old fart
No need to apologize Tony, you're not the only one to be financially challenged, I have to watch my pennies through a microscope. :blush: :blush: :blush:
Thanks: blue123
19 Jun 2014 14:35 - 19 Jun 2014 14:36 #325 by Phil Wood
Replied by Phil Wood on topic Auster mk5
That interior looks better than the inside of my car, will it have an ash tray & a beer glass holder? :lol: ... you're a stickler for detail Tony, I'll say that for you. ;)
Last edit: 19 Jun 2014 14:36 by Phil Wood.
23 Dec 2014 15:31 #326 by Ex-Member
dug this out as i have no depron.
adding some rivets.
probably not right, but what the hell.
23 Dec 2014 17:24 #327 by Ex-Member
more rivets.
24 Dec 2014 08:24 #328 by Ex-Member
Hmmmmmmmmm........................... Haven't I seen that picture somewhere before????????? :) :) :)
03 Jan 2015 20:09 #329 by Ex-Member
slopped some white paint over the rivets and left to dry.
will do another coat another day.
i hope to sort the lower strut mounts out on monday after i have sorted the workshop out.
i think i will order some 3mm piano wire to use to make up the struts and then cover them with balsa to get the right shape.
03 Jun 2015 17:50 #330 by Ex-Member
Well after a short break i thought i best do some more.
deep breath and cut some aluminium channel to make the u/c mounts.
roughly in place, need some small screws now.
then i took another deap breath and bent the rear part of the legs.
the shorter bit runs under the fuselage to where the rubber suspension bungies fit.
need to drill some small holes to take the pivot bolts next and then i will bend the front legs.
ooooo eeerrrrrrrrrrrrrrr. :unsure:
Time to create page: 0.928 seconds
