avro shackleton mk111
Just a thought, but it may be worthwhile considering thinner stringers, or even laminating them from several thin strips so they go around the curves better. That coupled with the thicker wood that you've already proposed should cure the problem.
sanded the nose block down to shape, filled a few holes and made some guns.
then i worked on the gunners position frame work, needs sorting a bit still.
Then i took a deep breath and cut a hole in the underside.
then i lined it and this is where i am at now.
- Gary
- Senior Member
- Thank you received: 125
In response to your earlier comment about strength, I believe we all make our models far too strong. As this is a test machine, you'll be able to see where it breaks, if at all, and then add strength where it needs it for the 'production' machine.
In the Indoor world, we make our models as light as possible, we fly them and see where they break. On the next model we make that bit stronger and the rest of the model weaker. After several iterations, we end up with a model that's half the weight of the original and less likely to break anywhere on the machine. I'm not suggesting you go to those extremes, but you could do at least one iteration if you felt it appropriate.
- Tony F
Tony
- a4kskyhawk
- Thank you received: 1284
and also by the picture it looks like a big model
if i had done it to the same scale i would be dealing with a 13' wingspan. eeeeeeeeeeeeeeeeep
10' is big enough.
- Sarah-Jane Smith
- Gone
- Thank you received: 2182
took 2 goes and i am still not fully satisfied, but i think with some sanding and when painted they will look ok.
then i cut out the top hatch and made the sun roof.
where we are this evening.
if i get a chance tomorrow i will make up the other two front screen frames.
