- Thank you received: 690
- Septic
I am going to use the .5mm carbon in the 6 main bracing tubes that go up to the wing. Not worked all the kinks out yet, but possibly inside rounded balsa to make up the size. I may also add some of the .28mm to add tensional assistance to the struts.
Will be off air for a couple of days as I need to be somewhere.
Cheers
Danny
tap - tap.......rivet
- Septic
Cheers
Danny
A carbon rod has huge tensile strength, maybe 50 lbs for even for the smallest diameter, but only a tiny fraction of that in bending or compression.
If a carbon rod is used in a location where the load in any direction is measured in just an ounce or two whilst it will work it is not actually the lightest solution.
A 'strut' made of the sort of things Andy suggests will have a more useful combination of strength and rigidity and perhaps more importantly it can be efficiently fixed to the rest of the structure.
- martynk
- Premium Member
Are you still working on this?
Martyn
Martyn
- Septic
Cheers
Danny
- martynk
- Premium Member
I have to admit that I thought you were being a bit ambitious for this years event. Still looking forward to see how it progresses though.
Martyn
- Septic
A bit more done, very much a making it up as I go along here....
Will lift this next and build the other side, might even make a starboard side to match this port side, there again I might just make another port, depends how much coffee I have in the morning :whistle:
- Septic
- Septic
Some of the cross bracing between the halves will be knocked out once the centre section is finalised.
Cheers
Danny
what is it
- Septic
I think it's an oil derrick
The good thing is the oil derrick is only 3.2g
Cheers
Danny
looking good sir Danny of scaleshire.
another fine build from you young man.
- Septic
Grabbed a few minutes to join the rear of the fuselage over the plan view.
The cub doesn't have perpendicular sides, so I am going to have to build out along the top of this structure, before adding the upper formers at the rear. I am not very good at this designing lark, there was probably a much easier method but this is how I have done it
Cheers
Danny
- Septic
Cheers
Danny
