72" span Avro Shackleton
starting small this time with a baby 72" span version.
if this one works ok i will build a bigger one to match Garry's Lancaster.
first part of the drawings done, i need to draw up all the formers for the fuselage yet and then think about the wings and such.
no rush at all as i am still plodding on with the biplane.
then i printed out the fuselage template.
only a 52" long fuselage ( for a change)
as with all my builds, i will be using the central core method and building the fuselage up in two halves before joining them together after they have been sheeted.
Thank you for watching
- Squirrelnet
- Thank you received: 2067
Monz built a beautiful rubber powered one, flew very well also.
Tony B.
Well I suppose it is compared to your Meteor!
- boz
- Thank you received: 1420
- Mowerman
- Thank you received: 139
then i printed out the templates and started cutting some Depron.
i have cut two of each part so that i can build each half of the fuselage separately.
each former was glued down with UHU Por and there ya go.
thank you for watching
- Geebs
- New Member
- Thank you received: 58
I was thinking on the lines, same as Mowerman, to use a TNijhuis subject and use his Avro York which has a fuselage cross section more akin to the 'Shack'.
I'll post a photo of a shack when I can dig it out.
Geoff
- Geebs
- New Member
in the real aircraft, when going from front to rear and vice-versa the crew had to clamber over the huge spar tunnel.
The shack was also used as a troop carrier, during the Suez and Cyprus crises, I think they used to carry about 18-20 troops, no seats for them.
The photo was sourced from The Growler Magazine Issue 115
- Monz
- Squirrelnet
- Mowerman
Then i tackled the tailplane and fins.
not going to have working rudders on this one as it will add tail weight and be not easy to do, there is not enough room in the tailplane for servo's.
still we are plodding on quite well so far.
hopefully be on the wings by the weekend.
keep watching
Tony B.
